Re: aggresive fitment legacys
Still racking some numbers here.
16x8 might work better. The steelies are 16x6.5 Subaru rims with a 48 offset. Adding 1.5 inch to the lip bring the offset to 28-29. Much more manageable.
for reference..
http://forums.vwvortex.com/showthread.p ... ht=steelie
Stretching doesn't affect outside rolling diameter. Running a different width isn't the end of the world with the same tire diameter; some of the old timeattack setups were experimenting with different widths front and rear to tune turn-in response.
It's getting different widths, even if you were able to match OD, that would concern me, because you're changing the "grip balance" front to rear. I'd expect a center diff to pack up in that case much quicker than any minor OD mismatch.
That said, I don't really like stretching.
That said, here's my car on 18x8.5's with a 225/40/18, lol. It's not herrafrush, would need a 15mm spacer, more camber, and more low.
https://sl-i.net/FORUM/images/import..._8517JPG-1.jpg
It does make for tons of room as far as fitment is concerned, I could lower the car another inch with no issues. Not really my style, but I got the tires for free and wanted to bolt on the wheels before I sold them.
Someone else already posted 18x9.5 +35... interested too see some more pics and side shots of your wagon on how much they poke. Any rubbing?
when I get her back, ill post pics... keep in mind my fenders are pulled..
@Sybir - What offset are those?
Quote:
Originally Posted by 2000gtb
What wheels are those, they look pretty darn good on a wagon!
Quote:
Originally Posted by wiisass
/thread
Do I spy a 2nd gen bumper....
Quote:
thought you ve noticed that before..
18X10 coming right up
https://sl-i.net/FORUM/images/import...MG_89981-1.jpg
still got plenty of room in the back but pushing it in the front.. will see how 18x10 will look
How much clearance in the rear - between the inner guard and wheel?
2000gtb... When you going to sell me your front?! I can trade you my outback front plus cash lol
front bumper??? its not perfected yet.. noticed the arc in front of the tires.. not perfect.. i am getting it re done then if there is enough interest, ill get a few made... you have to buy your own JDM fogs
Yeah fogs are no problems, perfect? Ehhh pretty darn close! Let me know!
aggresive has arrived.
17x9 +17 225/45/17 Blizzaks
If I end up keeping this car ill be running 215/40s and probably drop front down about 1.5" and rear 1"
https://sl-i.net/FORUM/images/import...7cc84b_b-1.jpg
Stylewagon........KEEP IIIIIT!!!
Best looking second gen so far.
ha, thanks guys. Didn't think id get so much love with this thing. I know it looks basically like a stock GT but in all honesty it started out as this:
the day I got it about 4-5 months ago.
https://sl-i.net/FORUM/images/import...08/lego2-1.jpg
Did you/someone jizz over the bumper?
Quote:
I bet he wet sanded his headlights and to polish them up and didn't wash everything off haha
Yes, wetsand and buff didnt wash it cause i was changing the front bumper the next day anyways.
New tires will be here by the end of the week. Car will get muuuuuuch lower, side skirts need to go back on.
Stupid questions... Just did brakes- calipers, rotors, dot4 fluid, SS lines.... Notice on all my brakes I have a angled/uneven pad wear on just 1 pad on each caliper. This doesn't have anything at all due to my super negative camber since the calipers attach to the entire hub correct?
That doesn't sound like anything camber oriented. One that that could do it is worn out wheel bearings. That would cause the hub to sit sightly angled while everything else is in place correctly. Thats my only guess.
Quote:
You should because not a lot of Legacys get fitment right. Stretch, poke, wheel gap and the 'cleanness' is spot on...
