Re: Dodik's 09 Tribeca Lowered
installed front 05 outback springs as time was scarce I didn't take any exact measurements of the drop, but its about and inch, ride quality didn't change in any noticeable way, just more refined leveled look.
in order to install outback springs you would also need outback upper spring perches, as the springs taper on the outback and not the tribeca.
You can not use 05 outback struts as the knuckle is thicker on the tribeca.
here some pics
https://sl-i.net/FORUM/images/import..._4144JPG-1.jpg
https://sl-i.net/FORUM/images/import..._4139JPG-1.jpg
