Page 2 of 2 FirstFirst 12
Results 31 to 49 of 49
Thread: LED gauge cluster conversion.
  1. #31
    13,377
    Re: LED gauge cluster conversion.
    Quote Originally Posted by 1-3-2-4
    yeah I know but at least when I last had LED's in the bulb holders if you dim it down all the way it was pretty good but then the rest of the dash is dim :P
    Next step is to use the same LEDs in the rest of the dash then... LOL.
    Brandon did you ever get my PM? it was months ago when my car was still not running. I had asked about if you could do the LED install for me if I shipped my cluster to you. Drop me a PM if you're still interested.
  2. #32
    SLi O.G. 1-3-2-4's Avatar
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    Points: 15,480, Level: 80
    lol that would just be the buttons for the rear defroster and fog light left.
    back
    3 4
    1 2
    Front
    97 Legacy Outback Wagon
    <--- 252,xxx miles!
  3. #33
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    From yesterday
    back
    3 4
    1 2
    Front
    <--- 252,xxx miles!
  4. #34
    "FNG" TexasLegacy2.5GT's Avatar
    May 2011
    32
    2,834
    32
    Points: 2,834, Level: 32
    Level completed: 56%, Points required for next Level: 66
    ^^^That looks so much better then the OEM!
  5. #35
    SLi O.G. d1giPhux's Avatar
    Dec 2005
    3,244
    20,084
    89
    Points: 20,084, Level: 89
    Level completed: 47%, Points required for next Level: 266
    Is it easy to get the gauges off without breaking the needles? Seems to be not much info on HOW you do it. I saw the post from before, but still looking for more info.
    http://tinyurl.com/2u8cbx
  6. #36
    Dec 2007
    Greenwich, CT
    2,202
    15,480
    80
    I never took off the needles..
    Are you referring how to sand under to get the kph and x1000/min?
    back
    3 4
    1 2
    Front
    <--- 252,xxx miles!
  7. #37
    SLi Supporter
    May 2010
    NJ - near NYC
    121
    4,737
    43
    Points: 4,737, Level: 43
    Level completed: 94%, Points required for next Level: 13
    Quote Originally Posted by d1giPhux
    Yes, once you get the gauge unit out of the cluster with the #2 phillips screws on the back, you will see a black mask of dots on the back of the faces. That mask is how Subaru dealt with the hotspots from the bulb locations. More dots equals less light to the front of the face. The green dye is under that mask so you loose the mask when you sand off the green stuff, hence the hot spots.
    Also if you go with replacement LEDs that fit in the original bulb locations, you end up with two different styles of LED. My choices from Superbrightled have a different color temperature.
    There are two #1 screws on the face of the speedometer and tach that hold the face on. Remove those and the face will spin without messing up the needles. Spin it 180 degrees and screw it back in to clear the rest of the face.
    Regardie
    1997 Legacy L sedan 2.2 auto - crushed by a tree during Sandy
    All upgrades stripped and returned to stock, started up when they hauled it away
    New to me 2000 Legacy GT Limited sedan 5 speed 180K miles
    184K and running on a JDM Bilstein struts and springs set and a replacement RS 5MT
    187K, engine top half rebuilt, Delta 1500 cams, PNP, converted EJ252 to EJ251 for Delicious Stage 1 flash
    190K worked out some engine issues with the swap, now Cobb EL headers and High Flow Cat and mid pipe, muffler shop axle back
  8. #38
    SLi Supporter N3M3S1S's Avatar
    Toronto
    3,175
    34
    Points: 3,175, Level: 34
    Level completed: 84%, Points required for next Level: 25
    Does this work for the BH? If so, where did you order the strips from?
    - BH to LGT conversion?
    - AJ
  9. #39
    SLi Resident HeresMyMind's Avatar
    Dec 2007
    southbury, ct
    517
    8,513
    62
    Points: 8,513, Level: 62
    Level completed: 21%, Points required for next Level: 237
    yes i got your pm and i responded with my mailing address... I need to order new LEDs then what color did you want to do?
    -B
    "This thing looks great in person, makes me think getting a wagon isn't so bad lol"
    -Reason
  10. #40
    OMFGAWD phi11's Avatar
    Jul 2005
    Apple Valley, MN
    866
    10,878
    Points: 10,878, Level: 69
    Level completed: 7%, Points required for next Level: 372
    I did This last night.
    Acetone will take the green off, instead of sanding.
    I just wish the needles would glow too.
  11. #41
    Dec 2005
    3,244
    20,084
    89
    The acetone won't eat through the paint and destroy the number markings and such? Guess you just gotta be careful about not getting it anywhere near the front!
  12. #42
    Jul 2005
    Apple Valley, MN
    866
    10,878
    Too much acetone will Destory it, yes.
    Take your time.
    I sprayed some acetone on a paper towel, then did a quick wipe on the back, let it dry.
    Wipe again, dry, wipe.
    At first I was using a dremel, the little drum sander, low rpms,
    After awhile it looked like the plastic was going to warp.
    Acetone took half the time.
  13. #43
    Jun 2012
    7
    1,966
    26
    Points: 1,966, Level: 26
    Level completed: 66%, Points required for next Level: 34
    Heres
    i have 2000 LGT and if i want to do that
    how do i know which is +/- red blk?
    can you tell me how can i find out please
  14. #44
    New User Teaf's Avatar
    Aug 2011
    13
    2,652
    31
    Points: 2,652, Level: 31
    Level completed: 35%, Points required for next Level: 98
    legacy89 can u bump me a link where i can get a set of red for my subie please>?
  15. #45
    SLi nOOb shoguy's Avatar
    Dec 2011
    York, PA
    104
    4,349
    Points: 4,349, Level: 41
    1000 Experience PointsRecommendation Second ClassO.G.
    bringing this one back from the dead... looks like you went with 3528 series LED strips, at night, how bright is it? is it so bright it affects your night vision? I am looking at going with Red, this looks awesome!
    -Rick
    1998 Outback-Lift kit, plasti dip camo tan, 03 WRX calipers, slotted rotors, header, high flow cat, custom 2 1/4 catback, vibrant muffler, fresh rebuilt .020 over EJ25D w/ 251 block, strut tower bar, etc...
    04 35th anniversary H-6 Outback-Dynomax VT Muffler, power mode mod, not much else......yet!
    85 V65 Magna
    86 'Zuki Quadsport-fun machine
  16. #46
    Jun 2012
    Christchurch, NEW ZEALAND
    132
    4,328
    Points: 4,328, Level: 41
    Level completed: 89%, Points required for next Level: 22
    Just saying (and reviving this brilliant thread) that there is a company in the 'states (you guys) called Import Intelligence who do glowing needle type stuff. By all reasoning these should work on our cars. Anyone tried them?
    http://yhst-27796775113468.stores.ya.../iminprli.html
    Yes officer, I did hit a pedestrian, but instead of dwelling on that why not focus on how many I've missed?
  17. #47
    Jun 2012
    132
    4,328
    Just pulled my spare BE gauge apart- it does not look easy at all
  18. #48
    New User ChickenJoe's Avatar
    Jul 2017
    Summerville, SC
    2
    Points: 1, Level: 1
    Hol up... no one has this done for a BE5 legacy? The gen 3? if so can I get a link or feedback? cheers!
  19. #49
    2,790
    Quote Originally Posted by ChickenJoe View Post
    Sure you can, I think there are some pictures around here somewhere.. that said, the BFM upgrade is a much bigger difference and far more impressive.
