Results 301 to 330 of 433
Thread: 98legwag's 09 3.0R Limited
Threaded View
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,526
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    Welcome to my thread/journal for my 2009 3.0R Limited. I bought it with 62,408 miles in September of 2013. It is stock, and I plan to keep it that way. I wanted a car that had everything I wanted. Both some performance and creature comforts. This fit the bill perfectly. I will pull some minor things over from the 98 wagon.
    Interior:
    LEDs in map/dome/trunk/door lights
    All weather floor mats
    45% tint on sides and rear winshield
    Liberal Albero carbon fiber shift knob / JDM Momo option shift knob / JDM STI option shift knob
    10 inch Polk Audio sub in a Wicked CAS Magic box to replace blown factory Harmon Kardon sub
    IAG floor mat bracket
    Exterior:
    Hella Sharp Tones
    LED tag lights
    DDM Tuning Plus HID kit 35 watt 4500K
    Fog lights- Osram Night Breaker Unlimited
    High beams- Osram Night Breaker Unlimited
    RREV LED reverse lights
    Vinyl overlays on front and rear emblems
    Bayson R lip
    Engine, exhaust & Trans:
    HKS ES Premium axle back
    Subaru OEM Battery Cover
    Subaru OEM Power Steering Cover
    Suspension, chassis, brakes, & Handling:
    Grimmspeed Brake Master Cylinder Brace
    Hawk HPS brake pads
    Tribeca 25mm front sway bar with Energy Suspension bushings
    Cusco front sway bar (need to install)
    JDM OEM 20mm rear sway bar with AVO polyurethane rsb bushings
    AVO reinforced rsb mounts
    Perrin front and rear endlinks
    Cusco front strut tower brace
    Cusco rear strut tower brace
    Mevotech aluminium lower control arms
    Wheels &tires:
    BBS RV723 (04 STI) 17x7.5 +53 wrapped in 235/45/17 General G-Max AS-05s
    Stock wheels 18x7 et55 currently wrapped in 215/45/18 Pirelli P Zero Nero M+S
    The day I brought it home:
    A couple days later:
