2.5L still,
old bore was 99.5mm x 79mm stroke x 4 cylinders = 2458cc
new bore 99.75 x 79mm stroke x 4 cylinders = 2470cc
12cc displacement bump or .012 L
I got heads today!, the valves were reground due to pitting, and the heads resurfaced by .003"
While waiting on the copper gasket spray to dry I added some Piston Wisdom™
Jeremy Clarkson inspired
Copper coated head gasket in place:
Heads installed:
Cams installed to check clearances
Thanks to the re-grind only one valve was in spec, going to mic the shims Thursday and find out how many I have to order and if I can just swap some around.
