Anyone knows if 02-07 WRX complete shifter assembly can replace 95 BK one? 95 fork joint at shifter looks bent 45 degree while WRX is more straight.
03 350Z - 120K DD
99 RS - Currently swapping JDM V9 207
98 RS - 145K JDM 20K V4 WRX
02 WRX - 150K DD
95 Legacy Wagon - 200K Winter Tahoe tank
If you replace the shifter knuckle and all it works. I've got an 02 wrx shifter assembly with a kartboy short shifter in my 97.
I had to keep the BK/95 shifter arm/wobble bushing part and swapped out WRX plastic base/shifter socket/hockey puck assembly, then I can use WRX short shifter with small socket. BK/95 socket shifter is very big compare to WRX socket and finding short shifter for it is difficult. All KB/Ebay shifter have small socket type. Bought some nylon flange bushings from McCaster P/N 6389K624 for $8 to fix shifter wobble issue and KB front/rear shifter bushings too.
Mine is this type since there are 2 types.
03 350Z - 120K DD
02 WRX - 150K DD
