This is my 98 Brighton I picked up from a friends shop before it made it to the scrap yard. Only $200 to save a Subaru's life. One of the toothed timing gear's bearing froze, then sheered all the teeth off the belt. Pulled the engine apart... wasn't good. Plus the interior on this thing was beyond awful. So with a dead engine and shit for interior why not take the down time to start by restoring the interior first.
Interior
Cusco chromoly cage
Suede headliner
Suede door cards
Longacre cage mounted rearview mirror
Custom deckless stereo
Scanguage 2
Sparco evo 3 seat
Takata 6 Points
momo steering wheel
Black dyed carpet and felt
LED tape modded cluster
Custom short shifter
Perrin shift knob
GPS
Longacre oil pressure and water temp guages
AIM Sports Mychron3 xg log data logger
Corbeau Forza passenger seat
Exterior
Custom grill
JDM headlights blacked out
HIDs
APR carbonfiber side mirrors
Bootleg s204 front lip
Pin strip removal
Engine
Eg33 swap
SARD FPR
2x high flow cats
Custom 2.5" exhaust
Group N engine mounts
Torque Solutions torque mount
Ground kit
SPT oil cap
Cusco rad cap
Griffin aluminum radiator
Chassis
Cusco Zero Wagon coilovers
Cusco front and rear sway bars
Cusco front and rear carbon fiber strut bars
Cusco rear lower tie bar
Whiteline front and rear trailing arm bushings
Whiteline adjustable rear control arms
Whiteline Bump steer correction kit
Whiteline front control arm bushing
Whiteline Anti lift kit
Whiteline rear swaybar heavy duty mounts
Whiteline rack bushings
DBA 4000 2006 wrx Front rotors
2006 wrx 4 piston calipers
Brembo cross drilled rotors rear
Stainless brake lines
Hawk HP Plus pads
Grimmspeed master cylinder brace
Ate Super Blue fluid
Torque Solution carrier bearing aluminum bushings
Cobb front and rear sway bar links
Energy Suspension shifter bushings
Group N tranny mount
Arp wheel studs
Kartboy transmission crossmember bushings
Kartboy rear subframe lock down bolts
5zigen 17x8 FN01R-C
225 Potenza RE71
First day at her new home
[IMG][/IMG]
Dark carpet
[IMG][/IMG]
Suede headliner
[IMG][/IMG]
Seat and padding in
[IMG][/IMG]
Finished grill with white badge. Painted in a satin finish. we'll see how it looks on the car but i might switch too a matte finish.
[IMG][/IMG]
Had to work over the bottom of the bumper with a heat gun to reshape it flat for the lip
[IMG][/IMG]
Lip added
[IMG][/IMG]
More heatgun repairs to a worn out bumper skin.
[IMG][/IMG]
after
[IMG][/IMG]
Scanguage testing out in my other Subi
[IMG][/IMG]
Moved the electrical units from the front to the side of the strut tower to clean up the bay a bit.
[IMG][/IMG]
Have to clean up some wiring shinanigans before its swap time.
[IMG][/IMG]
Stacking part till its swap time. looking forward to trying out Group N mounts
[IMG][/IMG]
[IMG][/IMG]
Deckless stereo setup
[IMG][/IMG]
[IMG][/IMG]
