Will a 00-04 trans work in a 1998? I get the final drive ordeal but I'm wondering if it'll bolt up and such.
It will bolt in and work, but you'll be missing one stud to attach the starter. '98 and below engines and transmissions are attached with 4 bolts. '99 and up are attached with 8, one of which takes the place of the lower starter stud and can't be used with an older 4-bolt engine. I've done it and only had one bolt attaching my starter before and it's not a big deal but you should be aware.
99 Legacy GT WRX - Now for sale!
05 Legacy GT Limited 5MT Wagon - Stock-ish.
02 Outback Limited 5MT - Lifted, Dual Range
84 Camaro Z28 - LS1/6-speed
85 Silverado - Low and slow tow rig
I have the same setup, for the starter I put a helicoil in the trans so the starter has two bolts.
When I ran my phase 1 block with my wrx trans, I just enlarged the hole for the starter stud, and tapped the transmission and used a larger bolt. It's not difficult at all.
All you guys and your fancy helicoils and tapped holes. Lord Flashheart and I know what what's up.
Lazy? I prefer the term 'motivationally challenged'
You'll need to swap your speed sensor as well, and I'll third the motivationally challenged vote of only using one bolt on the starter. Been running this way for almost a year.
Have fun swapping the speed sensor, I don't dare to summon such black magic. I'm also part of the one bolt starter group...
-Nick
1991 Subaru Legacy L -221K -Killed in action
1996 Subaru Legacy L -192K -Rust in Peace
1996 Subaru Outback -214K -Drove into ground
1999 Subaru Outback Limited -195K -Kiara. EJ22D. 5 speed swapped dual sunroof BG
1990 Volvo 240 sedan -220K -B230F. M47. I Drift Bro.
1964 Triumph Spitfire 4 Mark 1 -47K -First Love. Continuous Project. #BeingTopless 50whp of British fury!
Originally Posted by Thomistopheles
