Results 1 to 3 of 3
Thread: Replacement RH JDM projector headlight lens
    SLi nOOb LGT Kirby's Avatar
    Jun 2010
    Spokane, WA
    145
    5,227
    46
    Points: 5,227, Level: 46
    Level completed: 39%, Points required for next Level: 123
    Found a killer deal for a set of JDM Projectors. However the RH one has a crack on the far right side. Any suggestions? I know I could figure out a way to fix it, but was curious if I could get my hands on just a replacement lens instead.
    Any input is greatly appreciated.
    Been searching to no avail.
    Thanks.
    UNNAMED '97 GT Wagon just picked up. Build thread soon.
    "FNG" Michelle's Avatar
    Feb 2015
    55
    2,173
    28
    Points: 2,173, Level: 28
    Level completed: 16%, Points required for next Level: 127
    Unfortunately, I think your only option here is a replacement headlamp from JDM-land. The one-piece headlights we have over here may physically fit, but are not clear in the center like the JDM projector lenses are. This is so that the lens does not diffuse the projector beam output.
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    483
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    I repaired one.... using a USDM housing and lens and defluted the lens in the center... its quite a project but doable..
    1998 Subaru Legacy 2.5GT Sedan - Lucy
