Results 1 to 1 of 1
Thread: EJ25D, WRX turbo swap, Zener Diode for MAP sensor?
    "FNG" NZXTInerTia's Avatar
    Jun 2015
    Minnesota
    52
    751
    14
    Points: 751, Level: 14
    Level completed: 51%, Points required for next Level: 49
    So my options to regulate the MAP sensor from acting up are a Zener Diode, or a voltage clamp from Split Second.
    Can someone enlighten on a little more on running a 5.1v Zener Diode, more or less how to wire it, how the polarity goes, etc. I can't see spending almost $80 on the Split Second clamp, on a cheap boosted DD setup, that cost me less than $300 to do. Especially considering I have an AEM UEGO Wideband to buy, and a racecar in the garage that needs parts.
    Picture for entertainment.
    1998 Subaru Legacy 2.5GT (DD)
    1995 Mitsubishi 3000GT VR-4 (Show car)
