Results 1 to 5 of 5
Thread: Legacy power locks
    Legacy power locks
    Hey guys I had a legacy gt door (year??) swapped onto a 95 L chassis. There is the main harness but on the gt side there is a separate harness of red and lime green wires that don't connect to anything on the L side. How do I get my power locks restored? Currently I have to lock everything manually, but before I had the door swapped on, the power locks did work.
    Jul 2015
    12
    1,159
    18
    Points: 1,159, Level: 18
    Level completed: 59%, Points required for next Level: 41
Size:  381.5 KBName:  image.jpg
Size:  104.6 KBName:  image.jpg
    I think (doesn't count for much being a noob) that wire 21/24 depending on how you look at the plug (front or behind) is the only wire that's unaccounted for. Can someone help me out?
    2,790
    The driver door should have a VIN on it. that could help determine what year it came from, and in turn what FSM year to look at for wiring. Post it up, and someone can let you know.
    Jul 2015
    12
    1,159
    18
    According to door vin it's a 99 gt
    Jul 2015
    12
    1,159
    18
Size:  399.9 KB can someone help me make sense of this? This is a 99 gt door. My problem is I have an extra plug that has 1. Red wire with dark green stripe and 2. A lime green colored wire. This harness did not exist on my old 95 L door and is possibly keeping my power locks from working, most wires are connected/accounted for. If you look at my drawing, there is a missing black wire on the 21st plug from the door. I think it's the only missing wire but will check again since loom is dense and in tight space. What do you guys reckon?
