- Stuck Crankshaft Pulley
t3h ub3r m3mber
Rust penetrant and patience. The pulley won't pull straight off, you have to kind of "wobble" it off. A prybar or trying to pull straight off will just result in a lot of swearing and probably a broken timing cover. A 3-jaw puller (if the pulley is seized) will likely just pull the outer ring of the pulley off (it is only attached to the inner ring with a thin layer of rubber)
- You may not post replies
- You may not edit your posts
Forum Rules
