Results 1 to 25 of 25
Thread: Part numbers for BD/BG/BK Legacy 1995-1999
    10,378
    57,313
    Points: 57,313, Level: 100
    I found this on LERSOC, posted by are own "Huffer". Roger, hope you don't mind but this would be a nice help for people. I thought we had this somewhere but I can't find it. Please use this as reference only, thanks.
    Most credit goes to "Huffer" and anyone who contributes.
    The obvious between models won't fit.
    4EAT mount 41022AC150
    ABS Hydraulic Unit 27539AC05A
    ABS sensors 26740AA002 + 26740AA012 + 26740AA021 + 26740AA031
    Adjuster Assembly/Belt Tensioner 13033AA040
    Air Filter 12" short (K&N #33-2232) 16546AA020
    Alternator Assembly 23700AA34ARA
    Antenna Assembly (Power) 86321AC071
    Ball Joint (Suspension) 21067GA050
    Engine Block Heater A0910AS000
    Brake Pads - Front 26296AC021
    Brake Pads - Rear 26296AA062
    Brake Rotor - Front 26300AE070
    Brake Rotor - Rear 26710AC020
    Camshaft Sensor 22056AA062
    Car Cover
    Center Pipe 44200AC151
    Central Locking Remote Fob H7110AS020
    Crankshaft Sensor 22053AA052
    Cruise Control System (entire) H7010AC000
    Exhaust - Front Catalytic Convertor 44111AC162
    Exhaust - Gaskets 44022AA211, 44165FA000, 44011AC000
    Exhaust - Headers 44109AE031
    Exhaust - Rear Catalytic Convertor 44111AC172
    Exhaust - Y Pipe 44109AEO30
    Factory Security System upgrade (door protection, panic button, LED) H7110AS600
    Factory Subwoofer H6300AS030
    Fender plug 46059FA000 (96-99)
    Fuel Filter 42072PA010
    Fuel Injector 16611AA310
    Front ball join l(eft/right same) 21067GA050
    Grill mounting clips 91065AC100 / 91017AA010 grill mounting clip upper (x 4)
    Grill mounting clips 91059FC090 grill mounting clip lower (x 2, these go into the headlights.)
    Headlamp 84001AC222 & 84001AC232
    Hood Deflector E2310AS001
    Idler (Items A&B) 13073AA142
    Ignition Coil 22433AA400
    Ignition Wires SOA430Q122
    Intake manifold gasket (2.5) 14035AA281
    Keyless Entry Remote H7110AS020
    Knock Sensor 22060AA061
    Muffler Gasket 44022AA211
    O2 sensor - front 22690AA290
    O2 sensor - rear 22690AA220
    Oil Drain Plug Gasket 11126AA000
    Oil Filter OEM 15208AA060
    Oil filter K&N HP-1004
    Oil Pan 11109AA052
    PCV Valve 11810AA000
    Pulley Idler (with teeth) (Item E) 13085AA080
    Radiator - Lower Hose (incl. clamps) 45167AC010
    Radiator - Upper Hose (incl. clamps) 45167AA020
    Radiator Assembly 45199AC260
    Radio Bezel (woodgrain) J1310AC020
    Radio bracket LH 66132AC010
    Radio Bracket RH 66132AC000
    Rear Diff. Protector B0310SS000
    Rear Differential 4.44 (auto only)
    Side Skirt - Right 96051AC040
    Side Skirt - Left 96051AC050
    Spark Plug (each) 22401AA570
    Spark Plug x 4 22401AA570X4
    SPT Performance Muffler (SEDAN) SOA8376300
    SPT Performance Muffler (WAGON) SOA8376400
    Starter Motor 23300AA230R1
    Steering Rack - Boot 31232GA082
    Steering Rack Assembly 34110AA121
    STI Engine Mount - Left ST4100055120
    STI Engine Mount - Right ST4100055110
    STI Radiator cap ST4511355010
    STI Pedal Set (AT) C8110SA010
    STI short throw shifter (may not fit 95) C1010FA001
    STI strut mount (FRONT L+R) ST2031055000
    STI strut mount (REAR right) ST203704S000
    STI strut mount (REAR left) ST203704S010
    Strut Mount - Front 20320-AA100
    Strut Mount - Rear 20370-AC201 + 20370-AC211
    Struts - Front 20311-AC030 + 20311-AC020
    Struts - Rear 20363-AC010 + 20363-AC000
    Sunroof Deflector F5410AS020
    Tensioner Assembly 13068AA027
    Tensioner Assembly (ecentric) 13069AA063
    Thermostat + Gasket (Item B) 21200AA072 & 21236AA010
    Tie Rod End - Inner (Suspension) 34141AC010
    Tie Rod End - Outer (Suspension) 34140AC000
    Timing/Cambelt (Item A) 13028AA072
    Tire Valve 23142GA040
    Tweeter kit H6300AS010
    Water Pump + Gasket 21111AA110 & 21114AA050
    Wheel Bearings - Front 28016AA011NT & 2 SEALS
    Wheel Bearings - Rear 28016AA030 & SEALS
    Wheel Cap 28811FA240
    Wheels - 16" GT - Silver 28111-AC350
    Wing Mirror - electric no heat 91031-AC440NN & 91031-AC450NN
    Wiper Blade - Front SOA591U219
    Wiper Motor - Front 86511-AC081
    Aftermarket part #'s
    Group A end links (FRONT) GA-013-A
    Group A end links (REAR) GA-012-A
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1998 BK L PARTED
    13,377
    Heh, sorry - I probably should have remembered to post it here too.
    Some part numbers are not 100% correct - there were some Subaru changes over the years (notably the oil filters are now the same for all non-turbos, excluding H6, and I think we may even use the same filter as the WRX/STi, but I'm only 98% on that one).
    Best thing to do is to check the part number history with a dealership, before ordering.
    10,378
    57,313
    If you have a part name and part # post it up and I will add it to the list.
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    SLi Lurker Bdubs's Avatar
    Dec 2006
    Connecticut
    321
    7,547
    57
    Points: 7,547, Level: 57
    Level completed: 99%, Points required for next Level: 3
    Just did these today, figured I'd share.
    Valve Cover Gaskets (2)- 13294AA012
    Valve Cover Washers (6)- 13271AA051
    13 STi Sedan- Plasma Blue
    07 SE Sedan- Newport Blue- Sold
    91 Sport Sedan- Mica Ruby
    95 LSi Wagon- That famous green- Sold
    10,378
    57,313
    Quote Originally Posted by Bdubs
    for what car? what engine?
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    Dec 2006
    Connecticut
    321
    7,547
    57
    Oh, knew I forgot something, was too busy making sure the #'s were right.
    95 Leg, 2.2, will fit 95-99 years.
    10,378
    57,313
    I updated with some part numbers I had around the house. Anybody else have anything to add?
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    10,378
    57,313
    Come on guys, this will help others and you later on.
    I'll also take aftermarket part numbers too. Filters and spark plugs etc
    4Zero1 Motorsports
    2010 BM GT
    1998 BK L PARTED
    "FNG" AWD_PWNZ's Avatar
    Feb 2008
    Chi-city
    57
    5,731
    48
    Points: 5,731, Level: 48
    Level completed: 91%, Points required for next Level: 19
    any part number for a 98 legacy gt front bumper cover? i cant seem to find it even on subaruparts.com
    -95 20g'd ej255 powered 6mt'd gc8 impreza L
    -95 legacy -daily driver
    SLi O.G. decke48's Avatar
    Feb 2008
    TF Mass
    2,321
    10,706
    Points: 10,706, Level: 68
    M0010AS130 no-ob 98-99 full
    M0010AS121 ob 98-99 full
    M0010AS111 98-99 hood
    98 2.5gt
    MA.N/A 413
    SLi Supporter blackgtbeauty's Avatar
    Southern Vermont
    1,305
    12,110
    72
    Points: 12,110, Level: 72
    Level completed: 15%, Points required for next Level: 340
    You can, the N/A filters are just larger.
    -Rob
    Feb 2008
    Chi-city
    57
    5,731
    48
    Quote Originally Posted by decke48
    is this the hood with the scoop?
    and the 1st 2 numbers.. what are those? full what? sorry. im confused.
    Feb 2008
    TF Mass
    2,321
    10,706
    ob means outback? doesnt madder wouldnt cover the scoop. full cover, bumber and hood. $120 ordered from the dealer. there spt parts so dealers dont list them.
    http://www.subaru.com/microsites/spt/pa ... del=legacy
    did you mean the bumper?
    98 2.5gt
    MA.N/A 413
    Southern Vermont
    1,305
    12,110
    72
    I think he means the cover as in the skin, plastic over the beam.
    Not those bra things.
    I don't have the #'s on hand unfortunately.
    -Rob
    Feb 2008
    TF Mass
    2,321
    10,706
    i dont think dealers sell body parts
    98 2.5gt
    MA.N/A 413
    Southern Vermont
    1,305
    12,110
    72
    Like Subaru dealer's?
    Certainly, when I repaired my 99 BD and now my 01 BE I used genuine suby parts 100% from Subaru of Keene, NH.
    Skin, plugs, fasteners, everything.
    -Rob
    Feb 2008
    Chi-city
    57
    5,731
    48
    LOL yeah.. not that bra..hahah
    and no sir. dealers sells body parts.
    SLi Lurker AussieDan's Avatar
    Syracuse, NY
    483
    9,445
    Points: 9,445, Level: 65
    Level completed: 32%, Points required for next Level: 205
    97-99 GT front bumper 57730AC160
    Don't even think about trying to get a hood from the dealer, it will run you over $500 with the scoop.
    2007 Audi RS4
    1997 Legacy GT - 05 WRX conversion + more | December 2008 ROTM | SOLD
    SLi Lurker Wagonista's Avatar
    Mar 2008
    Utah County
    355
    8,459
    62
    Points: 8,459, Level: 62
    Level completed: 3%, Points required for next Level: 291
    Outback Fog Lamp LH 84501AC210
    [wagonista]
    '96 BG9 Legacy Outback // NA EJ22 // 5MT // daily for 9 years. She's still prowling the streets somewhere.
    '05 BP Legacy Outback // NA EJ25 // 4EAT // wifemobile, baby carrier extraordinaire
    '07 BP Legacy Outback Limited // NA EJ25 // 4EAT // the commuter
    '76 RA24 Celica GT Hardtop // NA 20R // 5MT
    SLi Lurker jjs316's Avatar
    Dec 2006
    NoVA, USA
    466
    8,083
    60
    Points: 8,083, Level: 60
    Level completed: 67%, Points required for next Level: 67
    Driverside (Left Hand) Trunk Hinge for 95-99 BD Sedans : 57520AC010
    Spinnin' Ain't Winnin'
    1997 Legacy GT 5-Speed Sedan...
    1995 Honda Civic Coupe DX...
    1997 Schwinn Homegrown Factory Full Suspension...
    OEM One Piece Headlights - Wood grain Interior Trim - Spline Drive Lug Nuts - OEM Replacement Long Lugs - FOR SALE
    SLi Resident Benfolio's Avatar
    Mar 2008
    Cedarburg, Wi
    550
    7,328
    56
    Points: 7,328, Level: 56
    Level completed: 89%, Points required for next Level: 22
    Clutch pedal pad 36015GA111
    2.5 Valve cover gaskets 13270AA062 and 13272AA063
    Plus the spark plug tube(?) o-rings 13293AA051 (x4)
    1997 2.5GT MT Sedan - Part out! - CLICK HERE FOR THE LIST/PICS
    1998 Legacy L Wagon - 204k and SOLD 6/10/12
    1997 C1500 Silverado Extended Cab
    2004 Quest 3.5SE Space Shuttle
    Feb 2008
    TF Mass
    2,321
    10,706
    http://www.subarupartsforyou.com/index.php
    just search up the part and get your number. its a dealer parts site.
    98 2.5gt
    MA.N/A 413
    SLi Supporter
    Usa
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    97' BD EJ25D
    806733030 Crank Seal
    806732150 Cam Seal (x4)
    t3h ub3r m3mber superu's Avatar
    Mar 2010
    Moab
    1,032
    7,787
    59
    Points: 7,787, Level: 59
    5000 Experience PointsSocialO.G.
    Re: Part numbers for BD/BG/BK Legacy 1995-1999
    I am looking for part numbers for a friend, but here's the deal... I'm looking for Australian (or European parts) parts.
    Does anyone here have access to such part numbers? Looking for the dual range center console covers accepting the low range shift lever, NOT available here in U.S. Center console meaning the console between front seats. I'll start with 95-99 legacy sedan/wagon,OB should all be the same.
    From fore to aft (front to rear) In U.S. there's the shift boot part, then then piece that goes next to the e-brake lever (mine has a little pocket in it, others may have ports for heated seats, outbacks? etc.), then the storage box console with the ash tray for rear passengers.
    thanks,
    -mw-
    9,857
    I have some part #s:
    Rear differential oil drain plug (bottom w/ magnet):
    383375200
    Rear differential oil plug (top):
    807025010
