I am trying my flickr account so look for the album links after each update.
So I finally took delivery of my soon to be track car. Heres the story...
1997 BD9 Legacy GT Limited
5MT / Sunroof
Originally from Quebec, Canada (No SALT)
Purchased from a local member in Ontario
Price $2000 CAN
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 481034969/Anyways I'll start my list of items:
Engine: None - None...
Maintenance items:
- None.
Drivetrain: None - JDM R160 4.444 LSD
Chassis/Suspension: BD6 - v.5 trailing arms
- noltec lateral links
Interior: - 1x Zero/Sport Carbon Kevlar fixed seat w/ aluminum rails/sliders. (not certified)
Exterior:-GD front fender flares
-rolled fenders
-GD ARP rear quarters (replica fiberglass)
-Carbon FX GT style hood (thanks Cajual)
[/list]
Wheels: - 01' RS 6-spokes (clears FHI 4-pots)
Brakes: - JDM front FHI 4-pot (black)
- JDM rear FHI 2-pot (black)
- JDM v.5 rear hubs w/ FHI 2-pot bracket
- SS brake lines front/rears
Audio: - None.. its whisper quiet
Carbon FX Hood
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 622002056/Zero/Sport C/F Kevlar Fixed Seat
Goal is to fit into a 36/38 before I can track.. Current 40/42
[GUT N' STRIP]--> Quick blurb.. removed most of the interior.. found an ebay short shifter and a 10 disc cd changer. as well as 2 mis-matched speakers..The previous owner was to cheap to buy an aftermarket wiring harness and decided to hard wire it directly.. Fucking nightmare!!
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 619314100/[GD 04-05 Fender flares]--> Quick blurb.. test fit with self tappers... still need to trim, rivet, weld, fiberglass, bondo, prime
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 743847414/-Need to hammer in the arch lip.
-Need to trim a bit more
-Need to bring out the bumper mounting point by 1" so it can flow with the flare.
----------------Mar/13th/2010------------------------------------------------------
Picked up a set of fiberglass 02-07 GD Impreza ARP (replica) rear quarter panels. Bought these from a local member for $250 and found out that they were made by Vince from VKinnovation.
Here are a few pics of the fenders + the body shop process (for an Impreza not Legacy!) + Finished look
Above are the fiberglass replicas. My Flickr link below had the photos of the the under layers. There basically a 1" x 2mm outline of all the panels that get "glued" down to the quarter panel and then the fiberglass panel can get screwed into place which gives a "flush" look. But since this is a legacy and nothing from a GD actually fits I am going to toss them and go with a full fiberglass molded quarter panel.
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 612496460/This widebody kit is out of this world but IMHO its just to wide and boxy for my taste.
So.... The plans...
0) Fiberglass both sections together and cut the new door line.
1) The combined length of both door skin and quarter panel is almost 5 foot. So I plan on shorting it by 1-2 feet at the same time .
2) This should shorten the depth of the arch by 1-2" The original ARP arches are almost 4" and that's a tad big for me.
3) I might delete the gas door and go with a fill-in-trunk fuel cell OR use the gas door and go with a standard filler-neck fuel cell.
4) Not sure if I am going screw/rivet/sheet metal brace the underside.. there are so many options..
Expect photos of the the "mock-up" stage by April-May..
I couldn't help myself... Rough mock up. Fits pretty good. Thanks 3M :-D
87/ [/b]
----------------May/3rd/2010------------------------------------------------------
Cusco Safety 21 Around-dash 8-point Roll Cage *GC8*So... I scored a GC8 Cusco 8-point roll cage thats missing one chromoly bar for the low price of $200 CAN. I don't know what I am going to do with this...
Options:
a) Get the chromoly bar, test fit and bolt together
b) Get the chromoly bar, test fit and weld it together
c) Use the cusco design and weld a custom cage then sell the cusco to my buddy with that white gc8.
Flickr Album -> http://www.flickr.com/photos/43663513@N ... 853762127/----------------June/6th/2010------------------------------------------------------
Rolling Adjustable Body Dolly... So space in my garage is a little tight so I decided to go "ALL-OUT" and build a Rolling Adjustable Body Dolly.
NOTE: I am going to remove EVERYTHING from the car. Wire wheel, sand blast, paint strip the entire car! This will take many days if not months. So expect slow updates.
The Parts.
8x2" Swivel Steel caster with Rubber liner (helps to reduce noise and resistance)
8x2" Swivel Steel caster with Rubber liner with Foot Brake (helps to prevent the body dolly from rolling around when working)
3-ton Jack stands (I could of used 2 but these were on sale)
The Mockup
The Example
Example of the car on the dolly (not exactly to scale. Since I'm 6'3" and much taller then the final height measurements of the dolly.
The CostEverything has been purchased from
http://www.princessauto.ca (local supplier for Canada)
2x 8x2" Swivel Casters @ $43 CAD
2x 8x2" Swivel Casters w/ brake @ 45 CAD
2x 3-ton Jack Kit @ $35
Raw metal @ $100
4x Ratchet Straps @ $36
$382 + 13% Tax
Total $431.
The Process1) Raise car body from rear and front subframes to appropriate height with pump jack and stands.
2) Roll body dolly under car body
3) Adjust cross bars to proper length/width and tighten locking bolts
4) Adjust Jack height and affix locking pin
5) Lower car body on to Jacks
6) Remove subframe pump jack and stands and roll the dolly around in the direction needed.
Not bad for a custom made dolly.
and to celebrate the sturdy acomplishment we decided to pull the rear end.
All pics uploaded to flickr.. check below
[b]Flickr Album ->
http://www.flickr.com/photos/43663513@N ... 6236054317Till next time SLi
Take it easy keep it sleazy!
