DIY: Install dual power outlet (56k, take a nap)
Ok folks, this was easy to do, and I took quite a few pictures to help out along the way. The part I got is listed as being for 97-99 Legacy. It costs like $8 at your friendly local Subaru dealer. First off, here's the box, showing the part number.
https://sl-i.net/FORUM/images/import...6/12/box-1.jpg
Now, on to what comes in the box.
There's a mounting plate.
https://sl-i.net/FORUM/images/import...12/mount-1.jpg
The power sockets themselves.
https://sl-i.net/FORUM/images/import.../outlets-1.jpg
Wiring harness to wire it all up
https://sl-i.net/FORUM/images/import.../harness-1.jpg
And finally the relay.
https://sl-i.net/FORUM/images/import...12/relay-1.jpg
Of course, it also came with directions to do the job. I'm modifying them slightly to suit my needs, but will show both how the directions say to wire it (mostly) and my way. This is my wife's car, an auto trans car. I'll be doing the same job in my 5MT car, procedure should be very similar.
As with any electrical work on your car, you should disconnect the negative battery cable before beginning this project.
First off, you need to remove some trim panels to make life easier. Start by lifting the lid on the console between the seats and remove the 2 screws holding the parking brake trim panel.
https://sl-i.net/FORUM/images/import...12/step1-1.jpg
The panel will now just lift out. I left the wires for the heated seat switched hooked up and just set the panel to the side. Next you need to remove panel around the shifter. This will vary depending on if you have an auto or manual trans. For the auto, first pop off the small panel around the shifter.
https://sl-i.net/FORUM/images/import...12/step2-1.jpg
Then, with the shifter in N or farther back, you can pop off the rest of the panel, simply lifting it from the rear. (Manual trans is similar, unscrew the shift knob and then you should be able to lift the entire panel/boot/knob up over the shift lever)
Next, I went for the trim around the radio, starting off with removing the cupholder. In the pic, you can see the cupholder is pulled out partially to expose the screws, there's one on each side.
https://sl-i.net/FORUM/images/import...12/step3-1.jpg
After removing the screws, the cupholder just pulls out of the dash.
https://sl-i.net/FORUM/images/import...12/step4-1.jpg
Next, simply lift up the panel above the cupholder to get it out of the way of the panel we need to remove.
https://sl-i.net/FORUM/images/import...12/step7-1.jpg
Then, remove the ash tray. Pull it out, press down on the tab and completely remove it from the slot.
https://sl-i.net/FORUM/images/import...12/step5-1.jpg
Re: DIY: Install dual power outlet (56k, take a nap)
I FINALLY FOUND/BOUGHT ONE AT A SUBARU DEALERSHIP 2000 MILES AWAY!!!!!!! IT IS BEING SHIPPED AS WE SPEAK.
AND IT ONLY TOOK ME 4 MONTHS OF LOOKING!!!!
I WILL UPDATE ONCE IT IS IN.
i have an '06 legacy i want this
^that post amuses me, hahaha
awesomeness!!
Does anyone know if there's a similar (probably different model year and model) "factory" mod to include AUX and USB (only for power) ports? I would love to add an AUX female plug and USB port (just for charging) to an OBS but I want it to look factory. I've seen later model foresters with the ports in the console, but it would be slick to have it on the dash or center console somewhere, or even a switch blank like by the knee panel.
Hmmm. . . .
There was an Aux panel in 4th gen.. That could be made to work..
