What an awesome journey your post has taken. Love your detailed pictures as well. Without a doubt the best year / color and model STI.
Printable View
^ Thanks
I've pulled the CAI off the car and gone back to the short ram, every time it rained it would throw a code for the maf voltage, requiring a ecu reset to clear. It'll go back on in the summer, the 4degree above ambient is too good to miss out on.
Finally got a wide band so that I can monitor the car better and dial the OTS tune in with the intake:
https://sl-i.net/FORUM/images/import...BCQSdx1h-1.jpg
https://sl-i.net/FORUM/images/import...uXEofn1h-1.jpg
I've got the 5V out wired into the analog input from the rear O2 sensor so I can log the wideband without needing a laptop and serial cable hooked up.
Then the multi disk changer died, and I took it apart to attempt to get the disks out and while it was apart I did a color change on the buttons:
https://sl-i.net/FORUM/images/import...7EpyC3tl-1.jpg
Finally got a turbo blanket from PTP and got around to installing it:
https://sl-i.net/FORUM/images/import...ZHFtnPJh-1.jpg
https://sl-i.net/FORUM/images/import...4Dsp9ulh-1.jpg
This is the craziest thing, I left the garage after installing it and did several pulls and quickly pulled back into the garage and was able to touch the turbo heat shield without burning myself.
Finally getting close to a Protune, so time to make sure the fuel system can handle it
ID1000's
https://sl-i.net/FORUM/images/import...0fy9gCPh-1.jpg
DW300
https://sl-i.net/FORUM/images/import...bcz15Nxh-1.jpg
Install time
fuel pump was straight forward, but the supplied wires from DW were a smaller gauge than the stock wires
https://sl-i.net/FORUM/images/import...CvMbpw0h-1.jpg
Assembled pump assembly
https://sl-i.net/FORUM/images/import...Mx5onwdh-1.jpg
new vs old injectors:
https://sl-i.net/FORUM/images/import...rzvw5K3h-1.jpg
using the data from Injector Dynamics until a protune in October, wide band was happy during a pull and looks good in closed loop.
Moved the AOS to make some more room for a GR intercooler that's waiting to be installed
GR vs GD intercooler:
https://sl-i.net/FORUM/images/import...JGBuVsCh-1.jpg
Before AOS move:
https://sl-i.net/FORUM/images/import...JqXP1Iph-1.jpg
after the IAG rotated turbo / Big intercooler bracket:
https://sl-i.net/FORUM/images/import...xXbx6CZh-1.jpg
GR intercooler bracket is here:
https://sl-i.net/FORUM/images/import...DcGSYPuh-1.jpg
I didn't feel like trying to fight with the lower end of the bracket where it would bolt to the TGV's
https://sl-i.net/FORUM/images/import...cNFIxMRh-1.jpg
GR intercooler installed
https://sl-i.net/FORUM/images/import...MQa3J7Nh-1.jpg
Spliter fitment:
https://sl-i.net/FORUM/images/import...yVavdonh-1.jpg
https://sl-i.net/FORUM/images/import...fsraduhh-1.jpg
Going to have to do some work on the spliter to get the most out of the bigger intercooler.
Friend of mine picked up a NA long block, and gave me a light weight pulley that was on it
https://sl-i.net/FORUM/images/import...qIksSo2h-1.jpg
https://sl-i.net/FORUM/images/import...Fflr87Lh-1.jpg
Finally got the inter-cooler stencil,
prepped the engine bay
https://sl-i.net/FORUM/images/import...FaciW29h-1.jpg
Stencil applied
https://sl-i.net/FORUM/images/import...dykZoFUh-1.jpg
Painting, 3 coats of high temp red caliper paint
https://sl-i.net/FORUM/images/import...YOIqeQNh-1.jpg
End result:
https://sl-i.net/FORUM/images/import...yX0EA4rh-1.jpg
Going on the rollers at EFI Logics this Saturday!
The big day finally came, got the car up to EFI Logics for a protune by Calvin Dotson of Dotson Tuning.
Got the car all strapped down
https://sl-i.net/FORUM/images/import...NHX6ZBzh-1.jpg
baseline pull:
https://youtu.be/-aIN91i6QSw
Results
https://sl-i.net/FORUM/images/import...9SKLTTWh-1.jpg
Before Protune
265 WHP & 284 WTRQ with some knock in the high rpms
After
275 WHP (+10) & 313 WTRQ (+29)
Knock free and stable AFR
I've very happy with the way the car is running, much more stable than the bro-tune I had done to get the car "ok" with all the mods it had done.
People say that Mustangs read low so you might have even more power. Good work!
Great thread. Thanks buddy! :)
Christmas means car parts, little bit of engine bay dress up:
https://sl-i.net/FORUM/images/import...RnbsqTbh-1.jpg
Burnt out my CB on the 48 HRS of Tristate drive, time to upgrade from the masking tape mount. Ordered a Cobra WX ST II CB and a JVC digital reciever.
Wiring mess, ran a coax extention from the CB to the trunk under the carpet.
https://sl-i.net/FORUM/images/import...ynHAa8Nh-1.jpg
https://sl-i.net/FORUM/images/import...vcZBGX5h-1.jpg
CB and new head unit installed. Had to enlarge one of the ISO/DIN mounting holes to get the cb perfectly lined up, then trim the radio bezel to fit the width of the CB
https://sl-i.net/FORUM/images/import...IaZGtpah-1.jpg
https://sl-i.net/FORUM/images/import...W5K13ZNh-1.jpg
Mic installed and wires for AFR gauge cleaned up
https://sl-i.net/FORUM/images/import...Pvt8n2bh-1.jpg
Getting the car prepped for seeing some of the stages of the New England Forest Rally this summer.
3/16" Thick skid plate from Primitive Racing
https://sl-i.net/FORUM/images/import...5yAKx4Kh-1.jpg
https://sl-i.net/FORUM/images/import...XlJcbjTh-1.jpg
The 1/4" thick mini rear diff protector from Primitive
https://sl-i.net/FORUM/images/import...rk7BwYJh-1.jpg
Installed
https://sl-i.net/FORUM/images/import...SPmt86xh-1.jpg
It clears the fumoto valve
https://sl-i.net/FORUM/images/import...98W6hpng-1.jpg
https://sl-i.net/FORUM/images/import...QBEqZBeh-1.jpg
https://sl-i.net/FORUM/images/import...u0pND2kh-1.jpg
The important part, sticker installed
https://sl-i.net/FORUM/images/import...Oqs92iih-1.jpg
Last pieces came in for the CB install
Panavise mount, 2" square tubing end plugs, & CB Mic mount
https://sl-i.net/FORUM/images/import...wOEtjHAh-1.jpg
Re-enforcement for the mic mount
https://sl-i.net/FORUM/images/import...7h9V0Iqh-1.jpg
Mic mount on the square tubing end
https://sl-i.net/FORUM/images/import...ZhSI5fUh-1.jpg
All assembled
https://sl-i.net/FORUM/images/import...GbnzDbVh-1.jpg
Installed in car
https://sl-i.net/FORUM/images/import...AZ4WN9Fh-1.jpg
Complete
https://sl-i.net/FORUM/images/import...5hWYWABh-1.jpg
