This works on the phase 1 4EATs from 90ish to 99ish. I don't know if it works on the phase 2, they may have a sport mode version but I have never looked into them.
So this weekend I took a page out of the SVX mods and wired my 98 Legacy 4EAT to stay in power mode at all times. The electronics on the tranny are the same as the SVX ones so it worked perfectly.
I did my research from these sites and don't take any credit for thinking this up.
http://www.alcyone.org.uk/ssm/powermode.html
http://www.subaru-svx.net/forum/showthread.php?t=39133
It works on the legacy just like the svx, but in 96 (at least in the svx) they removed the power light so you don't have a light on the dash when in power mode. All you have to do is run a wire from pin A4 on the first TCU connector to ground.
This is the connector and the empty spot is pin 4. I didn't unplug my connector to do the mod (not my picture).
My picture of it, wiring harness NOT in the car.
The TCU is mounted just to the left of the steering column, you don't need to remove any of the interior parts. I just looked under the dash, removed the 2 10mm bolts holding the TCU on and then ran a wire from that pin and grounded it to one of the TCU bolts when I bolted it back up. I didn't have a terminal from the connector so I cheaped out and just stripped the wire back and pushed it into the hole then wire tied it to the harness. I will get some pictures tomorrow of how mine looks and post them up.
This is where you look under.
Here's the TCU bolted to the brake pedal bracket and you can see the blue wire I ran and grounded to the mounting bolt.
The wiring harnesses are on the left side of the TCU. I unbolted the TCU so I could get to them, it's the top connector. You can see where I wire tied it to the harness to keep it from moving.
