Page 1 of 3 123 LastLast
Results 1 to 30 of 85
Thread: DIY: 4EAT phase 1 power mode wiring
    SLi nOOb TireIron's Avatar
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    Points: 4,690, Level: 43
    Level completed: 70%, Points required for next Level: 60
    1000 Experience PointsO.G.
    This works on the phase 1 4EATs from 90ish to 99ish. I don't know if it works on the phase 2, they may have a sport mode version but I have never looked into them.
    So this weekend I took a page out of the SVX mods and wired my 98 Legacy 4EAT to stay in power mode at all times. The electronics on the tranny are the same as the SVX ones so it worked perfectly.
    I did my research from these sites and don't take any credit for thinking this up.
    http://www.alcyone.org.uk/ssm/powermode.html
    http://www.subaru-svx.net/forum/showthread.php?t=39133
    It works on the legacy just like the svx, but in 96 (at least in the svx) they removed the power light so you don't have a light on the dash when in power mode. All you have to do is run a wire from pin A4 on the first TCU connector to ground.
    This is the connector and the empty spot is pin 4. I didn't unplug my connector to do the mod (not my picture).
    My picture of it, wiring harness NOT in the car.
    The TCU is mounted just to the left of the steering column, you don't need to remove any of the interior parts. I just looked under the dash, removed the 2 10mm bolts holding the TCU on and then ran a wire from that pin and grounded it to one of the TCU bolts when I bolted it back up. I didn't have a terminal from the connector so I cheaped out and just stripped the wire back and pushed it into the hole then wire tied it to the harness. I will get some pictures tomorrow of how mine looks and post them up.
    This is where you look under.
    Here's the TCU bolted to the brake pedal bracket and you can see the blue wire I ran and grounded to the mounting bolt.
    The wiring harnesses are on the left side of the TCU. I unbolted the TCU so I could get to them, it's the top connector. You can see where I wire tied it to the harness to keep it from moving.
    mine:
    '98 Legacy 2.5 GT Limited 5MT white sedan
    '96 SVX LSi 4EAT green
    for parts: '97 Legacy 2.5 GT 5MT white sedan
    SLi Resident green97gt's Avatar
    Apr 2009
    St Cloud FL
    808
    6,909
    54
    Points: 6,909, Level: 54
    Level completed: 80%, Points required for next Level: 41
    Re: 4EAT phase 1 power mode wiring
    and in essence this just makes the shift hard and late all the time? or?
    1997 Subaru Legacy 2.5GT 100% stock 190K+
    1996 Nissan Quest- 230k "Quasimodo" w/ Jacobs-omni ignition, ghetto hood scoop+CAI
    2006 Subaru Legacy Outback sedan 64k- Bone stock, garage princess.-step moms
    2007 Subaru Outback 40K-bone stock-dads
    2000 Subaru Outback 174K-the sis's ride way over on the WC
    1972 Mercedes Benz 350SL 140k w/ 4.5L Stuttgart V8-dads..again
    1981 Honda Express SR 49cc-32MPH of noisy, smokey, fury
    1980 Triumph TR7 2 litre convertible. 92k
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    not at all. This makes the auto stop hunting for gears and constantly trying to be in the highest gear it can. It makes a world of difference to how the car feels. It will definitly hold gears longer but it will only push them as long as you push the pedal. If you're easy on the pedal then it feels normal. The JDM SVX actually had a button on the console to put it into power mode, they just removed it for the USDM version so it is a feature that was originally built into the cars, not like the resistor to lock the center diff mod.
    You could also wire in a switch to this instead of hard wiring it to ground so you can switch it on and off. I figured I would never want it off, and if I do it's easy enough to either snip or unplug the wire. So far I've done about 500 miles on it (yes, that much since saturday, I did 250 today alone) and it is wonderful. The car is there when you use it, it doesn't lag and hunt anymore.
    mine:
    Apr 2009
    St Cloud FL
    808
    6,909
    54
    yerah, my first thought was it needed a switch.
    i wonder if it is at all harmful to the trans to be ran this way constantly...i would spose not if they put a button for it on some cars...
    i remember in our SVX that power light would come on....sometimes... when driving spiritedly, and other times it would not.
    this for sure looks like a better option than fiddling with the line resistor
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    Yea, I'll get some pictures tomorrow so you can really see just how easy it is to get to. It is definitely worth trying if you don't like the slushbox feel to these things. And it is probably better for the transmission because it is not hunting for what gear it should be in and slipping the gears to make it shift as soft. Harder shifting is better on the life of the transmisson (it's not jarringly hard or anything, just comfortably firm). When the tranny shifts soft and comfy like it is actually slipping the bands on 2 gears at the same time as it goes from one to the other, slipping the bands causes heat and wear on them and eats away at the life of the tranny.
    You could be trick and find a JDM power mode switch somewhere and wire that in hehehe.
    mine:
    SLi Supporter Grafton's Avatar
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Points: 12,386, Level: 72
    Level completed: 84%, Points required for next Level: 64
    you you take a video of the tach to show the difference in shift points?
    2007 Impreza WRX STi
    2012 Impreza 2.0i Premium CVT
    Sold 1997 Legacy L Sedan, 2.5L 12:1 Compression Hybrid, The 'Lego'
    RIP - 2005 LL Bean Outback, The 'Bean' & 1999 Impreza Outback Sport
    Jul 2008
    Fairmont WV
    1,731
    12,386
    72
    Hopefully this works with a 99 obs the 4eat in that thing drives me nuts
    SLi O.G. httrdd's Avatar
    Sep 2009
    NEPA
    2,700
    11,761
    71
    Points: 11,761, Level: 71
    Level completed: 28%, Points required for next Level: 289
    ^ + 1
    TJ
    99 LGT H6 Limited OBP
    A little bit of Wrx, a little bit of 2.5RS, a little bit of STi, a LOT of SVX!
    Will I ever supercharge this Eg33???
    Cheers and the Baja is not the bastard child.. The Legacy is :-D -Chuck
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    The shift point change depends on how much pedal but I will try and get some video of it at some point. Do some research to see what the 99OBS uses for a 4EAT and what it has for a TCU. I know my friends ex-gf had an outback sport and it was horrible but it had sport mode and as long as you kept it in sport mode it drove great, probably the same concept. I forget what year hers was though.
    mine:
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    Updated with pics, will still try and get the video.
    mine:
    Administrator Huffer's Avatar
    Eastlake, OH / Wellington, NZ
    13,377
    44,297
    Points: 44,297, Level: 100
    Great idea, never heard of it! If I still had an auto this would have been great! Snappier shifts are much better for an auto - slow shifts and gear hunting result in heat, which is the biggest killer of the 4EATs.
    Sep 2009
    NEPA
    2,700
    11,761
    71
    Suscribed!
    TJ
    SLi Resident evolegacy's Avatar
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    Points: 6,755, Level: 54
    Level completed: 3%, Points required for next Level: 195
    if this is as good as it sounds I might do this with my 4EAT, can't stand when it searches for the highest gear, gets annoying :smt012
    what gauge wire did you use?
    02 WRX wagon 5spd MT Daily Driver
    98 2.5 GT 4AT RIP
    99 2.5 GT 5spd MT RIP
    00 2.5 GT LTD 5spd MT RIP
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    it doesnt carry any current so even 18 is fine, i think that happens to be 16... I had it lying around from a coupe of amp install kits (the remote turn on wire they give) i like it because the blue really stands out.
    mine:
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    ok, next Q i guess would have to be since you didnt have a terminal for the connector, how secure is the wire in that spot?
    98 2.5 GT 4AT RIP
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    with the size wire I used its a pretty tight fit and then zip tieing it where I did keeps it in place. Next time I get by the junkyard I'll probly strip a few terminals out of a connector and put on in there. Just make sure none of the strands of wire get into a terminal next to it.
    mine:
    SLi nOOb legacy22's Avatar
    Detroit Lakes, MN
    4,504
    42
    Points: 4,504, Level: 42
    Level completed: 77%, Points required for next Level: 46
    Just did it was a bitch with the auto start box ziptied to the wires going to the TCU but i got it! i just notice my car has to at its running temp before it will shifft into overdrive! is that normal? Definitly can tell its not slipping between gears at all but like you said its not hard just firm! i like now i just hope my tranny dont blow up lol
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    The not shifting to OD until warm is part of subarus programming. The tranny shouldnt go into OD until warm, it's bad for it. Thats why if you live in a cold climate you should never eliminate the tranny cooler in your radiator because it can keep it from reaching operating temp.
    mine:
    Detroit Lakes, MN
    4,504
    42
    nice i figured it was supposed to be that way. I def. like the way it shifts now! For me it almost seems smoother!
    SLi Resident Matty2Hotty's Avatar
    Nov 2009
    Pacific NW
    907
    10,972
    69
    Points: 10,972, Level: 69
    Level completed: 31%, Points required for next Level: 278
    This work with my 01 lgt BE? I dont have no power mode switch or anything for my auto.
    97 RHD SOLD
    99 RHD SOLD
    01 Outback SOLD
    01 LGT SOLD
    "FNG" Stang70Fastback's Avatar
    Jan 2009
    4,680
    43
    Points: 4,680, Level: 43
    Level completed: 65%, Points required for next Level: 70
    Would this work on a 98 Outback? I assume it's all the same electronics?
    Needs to update their Email!
    Aug 2009
    madera, ca
    389
    5,513
    Points: 5,513, Level: 47
    im wiring mine up with a switch right now i hope it works, did it change your mpg any?
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    I think it may have given me like .5-1 MPG MORE because it is staying in the torque band more now.
    Yes it should work with your 98.
    The '01 has a phase 2 4EAT (started with the 99 model year) and I don't know enough about the phase 2 to know if this will work. I know they changed a lot about them when they switched to the phase 2 including adding a bunch more shift maps to the TCU. It may still have the ability to work, but I have no idea.
    mine:
    Jan 2009
    4,680
    43
    Sweet. I had a look under the dash and my problem is the keyless entry module is zip tied and attached directly in front of the TCU, so I can't really get to it at all. I don't want to start taking things apart to get to it, because who knows how it all works. Maybe I'll bring it to a mechanic and ask them to help me out since they could likey so it real quick. I'll get around to it one of these days as I'd like to try this out before my car kicks the bucket, lol.
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    Yea, my '97 had the keyless module right there. It's only ziptied there, so get some zip ties the right size, cut the ones there, move the module out of the way, do the mod, then zip tie it back up...
    mine:
    Aug 2009
    madera, ca
    389
    5,513
    i did it but i cant really tell a difference, maybe it shifts a little later but im not sure if its just in my head, i wonder if i put the wire in far enough, i i think i did. is there a way i can be sure its working?
    Dec 2008
    Lynn, MA
    806
    6,755
    54
    Quote Originally Posted by Stang70Fastback
    Dont disconnect the module, just cut the ties from it and move it to the side someplace. I disconnected mine while doin this and lost power to the power lock on the driverside door, annoying so I popped the unit back in.
    As for the wire, I didnt notice a difference so I assume I screwed up, Im just pushing it into the connector or am I pushing it all the way thru so the wires are coming out the other side?
    98 2.5 GT 4AT RIP
  28. #28
    Jul 2009
    Methuen, MASS
    190
    4,690
    43
    It needs to go in far enough to make contact with the pin on the TCU. If you've been annoyed with how the 4EAT shifts then you will really notice a difference when first driving it.
    The older models (possibly '95 and older?) should have a power indicator light on the dash that lights up green and says "power", but the newer ones don't, I think they removed it when OBD 2 came along.
    I stripped my wire back at least a 1/2 inch and then pushed it in as far as it would go (the connector was still plugged in). It went in easy for a little ways and then had a little resistance as it went the rest of the way in. I'm figuring this was where it was pressing in with the pin on the TCU. Doing it with the connector connected it cant really go in too far because it will bottom out on the TCU, as long as it doesn't start to press out sideways and connect the other pins, but you would really have to force it in there to make it go that far. And if you are worried about if it's far enough, just go strip a terminal out of a connector on a junk car and insert the terminal and use the wire connected to the terminal. Then you know it will be in far enough.
    mine:
  29. #29
    Aug 2009
    madera, ca
    389
    5,513
    i stripped it about 1/4 inch and pushed it in until it got hard, should i stripe it more or try to push it in more or both?
  30. #30
    9,857
    Re: DIY: 4EAT phase 1 power mode wiring
    Thread moved to DIY section. I will contact the OP about renewing broken image links.
