- Help floor jack problem
I have a powerbuilt 2.5 ton floor jack from kragen that won't lift anymore because the little hydraulic nub you push down on with the lever doesn't return back up so I can pump again. When I take a screw driver and pull the nub back up, I pump the jack again and the nub stays down.
If I pull the jack straight up from the lift point, it hold pressure just fine and stays up all the way. And there is no leaking oil from what I can see. The jack is completely filled with oil too.
Any help would be appreciated on helping to get this jack working
- You may not post replies
- You may not edit your posts
Forum Rules
