So i just got my JDM lights a couple days ago and not ten minutes after i got them they were in the oven. I put them in @ 200* for about 30 min and i could pull them apart with only my hands awesome. So im going to be doing a quad retro with 2010 RX 350 Bi xenon projectors and morimoto mini H1 bixenon projector. Im also going to be putting in CCFL hola rings and LED strips.
New joys in the box
all wrapped up
and here they are nothing new but still exciting
in the oven they go
apart and ready to start
Need the flange off the oem projector
mounted it to the RX projector note the black screws i drilled thru the bracket and used the factory 4 screw locations to mount bracket
i have it mounted in the housing but need to make some adjustments and tweeks
also had to cut off some of the back side of the projector under the soleniod
after someplaying around and pulling the other headlight apart i made some revisions to the bracket
this is both ready to go
I blacked out the housing and used the oen trim ring trimmed it so i could use it in my headlights
