Results 1 to 6 of 6
Thread: DIY EGR Tube Extension - Brazing
    SLi Resident 99gtlimited's Avatar
    Dec 2007
    Seattle, WA
    726
    9,746
    Points: 9,746, Level: 66
    Level completed: 24%, Points required for next Level: 304
    So I was waiting for a while to figure out a good way to lengthen my EGR tube so I can install my phenolic IM spacers, and eventually I decided upon brazing using an oxy/acetylene flame, bronze brazing rod, and flux.
    First I cut a spare EGR tube I had laying around in half.
    Next, I found a piece of steel tubing that was slightly larger, to make a sleeve, and cut a piece roughly 1 cm longer than necessary.
    Since the IM spacers are only 8mm thick, plus 2 IM gaskets, I have decided to lengthen the tube by approximately 10mm.
    Here's a picture of the final product, after sanding. You can see a bronze strip where the steel pieces meet.
    I decided to coat the entire thing with DEI silicone spray since I had some extra laying around. It is intended for use on exhaust pipes and should help slow/stop any corrosion/rust.
    Justin W.
    Continuous Improvement Project Leader
    Six Sigma Black Belt
    99 2.5 GT Limited "QuickSilver" 5MT
    07 Impreza 2.5i "Urban Grey Metallic" 5MT
    SLi Supporter
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    Re: DIY EGR Tube Extension - Brazing
    Very cool and ... old school :-D
    Gone and forgotten.
    Dec 2007
    Seattle, WA
    726
    9,746
    thanks! old school no doubt, but it got the job done. always fun to play with an oxygas torch, brazing rod, and an old can of flux
    Justin W.
    SLi Supporter LGTtoBE's Avatar
    Aug 2010
    Bowie, MD
    78
    5,268
    46
    Points: 5,268, Level: 46
    Level completed: 59%, Points required for next Level: 82
    What about using "soft" copper tubing as an EGR tube? Just cutting the nuts off, sliding copper through and flaring the ends?
    MySubie
    98 LGT White
    My engine swap-and-build thread (it's a SLOW process)
    THANKS FOR SUPPORTING MY ZAZZLE STORE http://www.zazzle.com/bangitout
    My 4Runner
    OMFGAWD phi11's Avatar
    Jul 2005
    Apple Valley, MN
    866
    10,878
    Points: 10,878, Level: 69
    Level completed: 7%, Points required for next Level: 372
    I had no problem re-bending my pipe by hand for phenolic spacers,
    but it does help if the engine is out.
    SLi nOOb AssYriaNrocKer's Avatar
    May 2012
    139
    4,045
    Points: 4,045, Level: 40
    Level completed: 48%, Points required for next Level: 105
    Old thread I know...but good work with that brazed in extension. I have 2 on hand right now so I'm going to try torching and stretching first and go from there.
    -RONI-
