Results 1 to 4 of 4
Thread: Which engine can replace the JDM EJ20tt for an upgrade?
    New User jdragon's Avatar
    May 2010
    3
    3,493
    36
    Points: 3,493, Level: 36
    Level completed: 96%, Points required for next Level: 7
    Hi guys,
    I have a 1999 JDM Legacy BH5 with an EJ20tt under the hood. What can I swap to keeping the ECU?
    Or is there an easier way to upgrade to the EJ25t?
    Please help asap!
    Rick TK BH5
    SLi Supporter
    Usa
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    Re: Which engine can replace the JDM EJ20tt for an upgrade?
    Replace the short block with an USDM EJ257. Swap over the crank sensor and such and you should be good to go.
    This method should increase your displacement with forged internals and still have the same timing and sensors as your EJ20G/K heads.
    PLEASE double check the crank sensor/any other sensor that connects to your short block. Check out NASIOC for more info.
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    He has a '98. So he doesn't have EJ20G/K. He has an EJ206 (or EJ208 if M/T).
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    Even still short blocks are interchangeable.
