Page 8 of 8 FirstFirst ... 678
Results 211 to 236 of 236
Thread: Baddog's 96 Legacy Hybrid - Frankenmotor Rebuild Again 6/13
  1. #211
    SLi Resident Baddog's Avatar
    Dec 2009
    Portland, Oregon USA
    935
    9,465
    Points: 9,465, Level: 65
    Level completed: 39%, Points required for next Level: 185
    Re: Baddog's 96 Legacy Hybrid - Frankenmotor Rebuild. Again
    Got the car running again last night. Bad ring placement or seat. Not sure really. But replaced the piston and threw new rings on it. No longer smokes.
    1996 Subaru Legacy L
  2. #212
    Dec 2009
    935
    9,465
    Re: Baddog's 96 Legacy Hybrid - Frankenmotor Rebuild Again 6
    Don't really update this anymore because...Well I just don't.
    But the 25D in my car is quite toast. Cylinder walls are too far gone from the blown ringland and I am blowing smoke again and getting low compression.
    Decided it's time to step up to a 251 short block. Got the block for 100 with a bad rod bearing. Going to clean it up and throw ACL race bearings in and new rings. New 10mm oil pump. Sti Oil pan, pick up, and windage tray.
    Hopefully this will be the last time I rebuild a motor for this car.
    Oh and a recent pic I took.
  3. #213
    SLi nOOb EJ22D's Avatar
    Nov 2012
    193
    2,277
    28
    Points: 2,277, Level: 28
    Level completed: 85%, Points required for next Level: 23
    That 251 is going to be tougher for sure. The 96 blocks are just not cut for that kind of treatment. Are you going to open the ports to those 22E heads a little?
  4. #214
    Dec 2009
    935
    9,465
    Quote Originally Posted by EJ22D
    Depending on cost yeah I may have the heads opened up some. Not sure how much benefit there is
  5. #215
    t3h ub3r m3mber harrymaneuvers's Avatar
    Mar 2009
    HighCal (aka NorCal)
    1,789
    11,027
    69
    Points: 11,027, Level: 69
    Level completed: 45%, Points required for next Level: 223
    Copy cat... hahahaha JK.
    Good luck.
    Mine is up and running except for a phantom oil leak at the rear of the motor but not anywhere on the "back" of the motor like the RMS or oil separator plate.
    The high compression with the 1000 cams sure does make the motor noisy though. Maybe that is just the exhaust though. I stripped one of the header studs out of the head when I was re-installing the headers last night so the drivers side is only being held by one stud/nut.
    Harry Maneuvers
    SOLD - 1984 Brat Turbo E81
    SOLD - 1989 XT6
    SOLD - 1991 Legacy SS
    SOLD - 1999 Legacy Sedan 30th Anniversary EJ251/EJ22 High Comp Frankenmotor http://sl-i.net/FORUM/showthread.php?15427
    SOLD - 2004 WRX Wagon Widebody - The Braggin Wagon http://sl-i.net/FORUM/showthread.php?15237
    2006 Forester XT - Mrs. Fancy http://sl-i.net/FORUM/showthread.php?15753
    2016 Outback 3.6R Limited
  6. #216
    10,378
    57,313
    Points: 57,313, Level: 100
    Mine was real noisy, I wrapped the header and its pretty quiet now, considering...
    4Zero1 Motorsports
    2010 BM GT
    1993 GSX-R 750 (version 2.0)
    1993 Suzuki GSX-R 750
    1998 BK L PARTED
    1991 Legacy SS SOLD
    SLi Facebook
    4Zero1Motorsports Facebook
  7. #217
    Mar 2009
    1,789
    11,027
    69
    Good to know.
    Harry Maneuvers
    SOLD - 1989 XT6
  8. #218
    SLi O.G. Muse's Avatar
    Jul 2012
    Willimantic, CT
    2,360
    10,774
    Points: 10,774, Level: 68
    Good luck, man. I really like your car.
  9. #219
    Dec 2009
    935
    9,465
    This will be the last motor this car gets. If it goes down hill again it will be a parts car.
  10. #220
    Nov 2012
    193
    2,277
    28
    Quote Originally Posted by Baddog
    The payoff is worth every penny. Much more power in the midrange & more power to be had all throughout the rpm. The powerband will stretch higher into the rpms as well, so a little more top end.
  11. #221
    Dec 2009
    935
    9,465
    Been forever. I put a 251 short block in. I still have idle issues. But not nearly as bad.
    Been prepping for Oct7ne's turbo build/swap. And working on the girls 95 prezza.
  12. #222
    Dec 2009
    935
    9,465
    Don't update this at all because the MR threads have gone down hill.
    However I am now runnin' a 251 with 25D heads and STI HG's. One of my more favorable builds so far.
  13. #223
    SLi Resident 1996Battlewagon's Avatar
    Aug 2007
    Rochester, NY
    944
    9,470
    Points: 9,470, Level: 65
    Level completed: 40%, Points required for next Level: 180
    Really!?! Do tell. What's the compression ratio on that? I've always preferred dual cam Subaru engines to single cams.
    Current:
    2005 Legacy Outback H6 (Battlewagon 2.0)
    Former:
    1999 Legacy Outback 2.5 5sp
    2002 Legacy Outback H6
    1997 Legacy Outback 2.5 5sp (Battlewagon 1.0)
    1996 Legacy L Wagon
  14. #224
    "Proby"
    Apr 2012
    East Berlin, PA
    247
    4,925
    44
    Points: 4,925, Level: 44
    Level completed: 88%, Points required for next Level: 25
    1000 Experience PointsO.G.
    that compression ratio should 10 to 1 but I am not sure I am running the same set up but with the stock Rs head gaskets so mines around 11.1 to 1.
    also, when you hit 3k with this set up if feels like vtec kicks in. i was getting good mpgs as well.
    Chevyman
    1993 Legacy FWD 4EAT "Daily"
    2006 Legacy Spec B "Project"
  15. #225
    Dec 2009
    935
    9,465
    It's about 10.7:1. Stock compression is 10.1 on a 251. This is a 251 with 25D heads and a THIN STI HG.
    I didn't notice any low end torque drop from my old 25D/22E cammed motor. I also did intake spacers, throttle body spacer (home made) and some other stuff to the motor. As well as an EL header.
  16. #226
    Dec 2009
    935
    9,465
    Was looking back at this. Not much has really changed at all. Going to be doing a turbo swap into the girls 95 Impreza soon. I have been spending all my car time helping Oc7ane get the turbo build finish. Which is now complete.
    The EJ251/25D is running good. Some blue smoke when I get on it. But the heads had around 220k on them without a rebuild. Currently just drive it.
  17. #227
    "Proby"
    Apr 2012
    East Berlin, PA
    247
    4,925
    44
    I am running the STi gaskets now on my build. I really miss the high compression but I was looking at having to change the head gaskets once a year. The compression blew out the stock RS HGs in 6 months, but I can run regular fuel now which I am happy about. I was spending 360-400 bucks a month on the old setup.
    Sent from my iPhone using Tapatalk
    Chevyman
  18. #228
    "Proby"
    Apr 2012
    East Berlin, PA
    247
    4,925
    44
    How much of a difference did the throttle body spacer and intake manifold spacers make?
    Chevyman
  19. #229
    Dec 2009
    935
    9,465
    R.i.p
    Well tonight the Legacy caught fire on the back passenger side near the header. I am unsure of what caused it. But after years of faithful service, she is now gone.
  20. #230
    SLi Supporter CaleDeRoo's Avatar
    Nov 2014
    Rochester, NY
    304
    3,390
    36
    Points: 3,390, Level: 36
    Level completed: 27%, Points required for next Level: 110
    Oh jesus christ that sucks
    BUT DIBS ON STUFF
  21. #231
    3,525
    Damn dude. Sorry to see it.
  22. #232
    Dec 2009
    Kaysville UTAH
    1,823
    9,426
    Points: 9,426, Level: 65
    That is about as shitty as it gets.
    I'm sorry bro.
    Hopefully insurance will cover it?
  23. #233
    "Proby" dynonacht's Avatar
    Jan 2014
    Farmington Minnesota
    242
    3,565
    37
    Points: 3,565, Level: 37
    Level completed: 44%, Points required for next Level: 85
    Quote Originally Posted by CaleDeRoo View Post
    BUT DIBS ON STUFF
    Too soon junior.
  24. #234
    Dec 2009
    935
    9,465
    I am back in a Legacy. I will get more pictures today. It has 270k on it. And needs a transmission (which I have).
    Not sure the plans I have yet. But after having a boosted Impreza. This will get boost someday.
  25. #235
    SLi Supporter Hinyo's Avatar
    Nov 2011
    Maryland
    483
    7,907
    59
    Points: 7,907, Level: 59
    Level completed: 79%, Points required for next Level: 43
    Tagger Second ClassSocial5000 Experience PointsO.G.
    Cant wait to see this progress =)
    1998 Subaru Legacy 2.5GT Sedan - Lucy
  26. #236
    "Proby"
    Apr 2012
    East Berlin, PA
    247
    4,925
    44
    Nice!!!! Welcome back!
    Chevyman
