Results 1 to 13 of 13
Thread: Leaky Moonroof.
    "FNG" skippymo's Avatar
    Jul 2009
    Lehigh Valley Pennsylvania
    97
    4,430
    42
    Points: 4,430, Level: 42
    Level completed: 40%, Points required for next Level: 120
    Leaky Moonroof.
    I didn't see a sunroof / moonroof area so i dumped it here. I have a leaky moonroof when it is really rainy it will wet the head board near the joint of the passenger side sun visor. I suspect a clogged drainage pipe. What is the best way to diagnose it or clean the tube / pipe out?
    thanks guys.
    "Never Try Never Fail"
    SLi nOOb ScoobySnack's Avatar
    Aug 2008
    Vancouver, WA
    137
    5,492
    Points: 5,492, Level: 47
    Level completed: 72%, Points required for next Level: 58
    Re: Leaky Moonroof.
    Had this problem, took off the headliner and you will see where the moonroof has two draining hoses on both the driver and passenger side. I took a metal clothes hanger and pull out a ton of leaves and debris. Not a hard task but just alot of work. So in the picture you can see the blue pvc hose I pulled that off of where it is connected and hook the metal hanger and work outside to push all the gunk out. Good luck.
    Jul 2009
    97
    4,430
    42
    Re: Leaky Moonroof.
    hot shit! now I have to remove stuff dang. oh well weekend project i guess.
    thanks so much.
    13,377
    Re: Leaky Moonroof.
    You can also hook up an air compressor to the end of the pipe and blow air down it to push more gunk out.
    It's also work taking off your front fender liner to make sure the drain is clear too.
    I can't wait till my sun roof stops working so I can have it removed entirely and replaced with a pop-up style one. I'll save 100lbs.
    Jul 2009
    97
    4,430
    42
    Re: Leaky Moonroof.
    i was thinking of using a compressor but didn't want to blow off the tube from the housing. even though you would save 100 lbs. I still don't like the look of the pop up ones. I'm going to stick with my in roof.
    SLi Supporter
    Usa
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    Re: Leaky Moonroof.
    I've fixed a few GT's with leaky sun roofs.. Usually its just the tube came loose and needs to be put back on.. Simple...
    You can pull your A-pillar plastic covers right off just find an edge and yank.. don't pull to hard though you may break a pressure clip. Once the pillar cover is removed you can just pull back your head liner and check out the issue.
    Jul 2009
    97
    4,430
    42
    Re: Leaky Moonroof.
    sweet... for sure checking that tonight then.
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    Re: Leaky Moonroof.
    oh removing the visors/rear view mirror helps pull back the liner evenly if you don't want creases in the liner. Its 3 Philips screws to remove the visors and mirror :-D
    Jul 2009
    97
    4,430
    42
    Re: Leaky Moonroof.
    oh right, thanks. I'll post my findings.
    SLi O.G. 98legwag's Avatar
    Moco, Maryland
    3,525
    16,957
    Points: 16,957, Level: 83
    User with most referrers
    Re: Leaky Moonroof.
    Our BH Outback is leaking on the passenger side of the moonroof. I dripps down by the Oh S! handle. I assuming the headline removal should be the same to get in there an check it out?
    13,377
    Re: Leaky Moonroof.
    ^^ yup, pretty much.
    Nov 2009
    Pacific NW
    907
    10,972
    Points: 10,972, Level: 69
    Re: Leaky Moonroof.
    Going to have to check mine, get a mystery leak out of the plastic trim up around the sunroof glass. Then drips down and pools on the ledge around headliner, drips right on me happened a couple times and am like WTF.
    97 RHD SOLD
    99 RHD SOLD
    01 Outback SOLD
    01 LGT SOLD
    Moco, Maryland
    3,525
    16,957
    Re: Leaky Moonroof.
    Quote Originally Posted by 98legwag
    It ended up being the windshield not the moon roof. The weather stripping was dry rotted and leaking. Windshield cracked on a trip and it got replace and no more leak!
