New plan for the Engine. See latest plans.
So, I WAS planning on having my new block ready before KABOOM!!!! But sadly... (see latest post)
NEW UPDATED PLANS:
EJ251 Short Block (GOT IT)
EJ25D HLA Heads (GOT EM)
11044AA632 .7mm Head Gasket (should provide 10.4:1 compression)
Delta Stage 2 cams
Flat-faced exhaust valves
Port and Polish
Custom exhaust (hopefully to include some 4zero1 pieces)
Upgraded water and oil pumps (GOT EM AND AN OIL COOLER)
The rest is all just add-on/external
May happen later on:
Neon upgraded coil conversion
Kartboy crank pulley
I'm looking for the best piggy back management I can get for $400 or less (if a good one exists)[/b]
[/color]
This is going to be a very lengthy build as (of course) I'm not made of money and will be doing the bulk of the work on my own.
I've done an awful lot of reading on these boards and this seems it will be a fairly reliable build. I'd really hope to see an increase of 35+ crank hp from this. Does anyone know if that is a reasonable number?
I would appreciate input unless it includes the terms: Swap, Sti, WRX, turbo, EJ257 (because it's not happening PERIOD)
