Results 1 to 8 of 8
Thread: USDM Turbo EJ20/EJ25 P/N (Block, rod, crank, head, valve)
    SLi Supporter
    Usa
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    Here's some info I found online while helping a friend build a hybrid motor. I will update this as I add to it...
    In North America Subaru introduced the 2006 WRX with a detuned STi 2.5ltr motor, smaller turbo and and bigger brakes 4/2 piston to accommodate the power increase.
    Also the 05+ Forester XT and 05+ Legacy 2.5GT also used the EJ255.
    EJ255 & EJ257 blocks are IDENTICAL!!!
    ---> That does not mean their internals are. the 257 has stronger internals.
    ---> Both are semi-closed deck.
    ---> The difference between the two are the piston dish and heads. The combination of the small chamber EJ255 head and shorter piston dome make the 8.4:1 CR. The EJ257 has a deeper head and taller dome, making 8.2:1.
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Re: USDM Turbo EJ20/EJ25 P/N (Block, rod, crank, head, valve
    Chuck strikes again! What would we do without this guy.
    Jul 2009
    Everett, Wa
    1,531
    7,580
    Points: 7,580, Level: 58
    Rumors that have not been cleared up..
    -The third number in EJ**_ is the turbo size...
    Hadn't heard that one - I thought since all STI's had a 7 at the end (post EJ20K motors) - that's what it referred to.
    NOOB
    Giggity
    oh boy, thats bad for canada!
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    Quote Originally Posted by mike-tracy
    no. The GC F and G model WRXs also had EJ207s. And the Forester STI (SG, not SF) and S402 both have EJ255s.
    "Proby" jamal's Avatar
    Dec 2008
    219
    6,967
    55
    Points: 6,967, Level: 55
    Level completed: 9%, Points required for next Level: 183
    Pistons are exact same material and if you put two next to each other and it's nearly impossible to tell the difference. It's all the same cast junk that cracks if you look at it funny. I have a whole box of subaru pistons with broken off ringlands and I even see it happen on brand new, bone stock <3000 mile stis.
    You should also give some credit to the guy who made that spreadsheet: Jeff Spounagle
    SLi nOOb omgshitsjrdn's Avatar
    Apr 2012
    Houston, TX
    159
    2,518
    30
    Points: 2,518, Level: 30
    Level completed: 46%, Points required for next Level: 82
    Noob question.. How much faster is a GT compared to an L, or LS? And what should I do to have a faster performance?
    1995 Subaru Legacy LS- SOLD
    1996 Subaru Legacy L
    SLi Supporter
    Usa
    4,530
    23,515
    Frequent Poster
    (Brighton/L/LS) 135 bhp (EJ22E) vs (GT/SUS/Outback/LSi) 165 bhp (EJ25D)
    EJ22E is a very reliable motor compared to the EJ25D
    Apr 2012
    Houston, TX
    159
    2,518
    30
    Im selling my car for a Gt when i.go back.to Houston. . And don't know what to start with for gains
