DISCLAIMER JUST a tutorial, proceed at your own risk
This fix is for when your window sometimes or wont go up or down... most likely its not the motor
Well, I have 2 BH, one an outback and a GT.. both had similar problems where the window switch would no longer roll up on the driver side due to excessive use or being worn out.. the first time it happened, I ended up buying new switch.. It cost over 100 bucks and did not feet like spending more money to fix the other switch in the GT.. So I decided to fix it on my own...
First Step is to take the switch panel off.. start from the buttom to avoid breaking the tabs, I used a flat head screw driver to pry it, disconnect the mirror plug then the window plug.. there will be 4 screws on the buttom, take those off and also take the backing off the switch...
