Page 1 of 2 12 LastLast
Results 1 to 30 of 50
Thread: Part # Software - Subaru FAST-2 (US/EU/JAP) <------ Download
    SLi Supporter
    4,530
    23,515
    Points: 23,515, Level: 94
    Frequent Poster
    OK so to make this simple here is the software that Subaru dealerships use for their parts look-up.
    Before we begine please visit Opposed Forces - Subaru Electronic Parts Interchageable Database
    Opposed Forces is a free interchageable parts site devoted to Subaru USDM/EDM . Its quick and 98% correct during my 4+ years using it.
    SLi Thread = viewtopic.php?f=14&t=15486
    Now moving on to FAST-2
    Its called FAST-II and below are links to download it. There is also a tutorial on how to install the cd, run the program, and use the search feature.
    Before you start please read this:
    1) This does not run on 64-bit Operating Systems. .. Deal with it..
    ---- VMware / Windows XP on Windows 7 64.
    ---- Or.. Microsoft Virtual PC (XP-Mode) works with Pro/Ultimate but there are guides to modify the install for Home Premium
    2) This does not work for "most" CDM/Canadian VIN's... However that being said.. out of 15 CDM VIN's that I put in only 1 came up...
    3) No BC / Gen 1 available
    4) You can do either VIN search or MODEL search.
    Download Subaru FAST-II (Parts Department Software)
    All files are hosted on third party hosting websites. We only provide links!
    ~~~~~~~~~~~~~~ NOTE ~~~~~~~~~~~~~~~~
    ~~~~~~ YOU MUST USE THE CORRECT ~~~~~
    ~~~~~~ SOFTWARE FOR YOUR REGION ~~~~~
    USDM(USA) & EDM (EUROPE) English Font
    MEGA.CO.NZ
    MEDIAFIRE.COM
    JDM (JAPAN) Japanese Font / Characters
    MEGA.CO.NZ
    MEDIAFIRE.COM
    Model Breakdown / Naming Codes
    USDM
    USDM EPC 2008.11 - 10811USSF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    USDM EPC 2010.03 - 21003USSF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    EDM
    EDM EPC 2008.11 - 10811LRSF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    EDM EPC 2012.05 - 21205LRSF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    EDM EPC 2012.07 - 31207LRSF
    MEGA.CO.NZ
    MEDAIFIRE.COM
    JDM
    JDM EPC 2010.04 - 21004SF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    JDM EPC 2010.07 - 10710SF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    JDM EPC 2011.08 - 31108SF
    MEGA.CO.NZ
    MEDIAFIRE.COM
    Download DAEMON Tools Lite
    Link -> http://www.filehippo.com/download_daemon_tools/
    Install.. Nothing fancy, just all the defaults besides "the crappy toolbars and what-not"
    Mounting the .ISO file:
    Once DAEMON Tools Lite is installed you should be able to mount the iso file that you downloaded earlier.
    Left Click the DT icon and select the virtual cdrom created.
    Select the .ISO file.
    .ISO file mounted and ready to use.
    Install FAST-II:
    Navigate to the virtual CD-ROM drive letter.
    Use "My Computer" and double click on the CD labeled "21003USSF".
    Navigate to CD-DRIVE**\sffastpg\win\
    Double click on "setup.exe"
    The next steps are simple. Just click ok and next and finish.. All default; nothing fancy just simple install.
    Setup CD Location:
    --> Here you can select multiple FAST-II CD's. You can load USDM / EDM and JDM.
    Select option 2). from the list [Setup]
    Select the Browse button for 1st CD ROM
    Browse to the mounted .ISO file. This is where you can choose which version or region of FAST-II you can use. You can repeat this step
    and load other .ISO files for the 2nd, 3rd & 4th CD-ROM for FAST-II to use.
    CD location set. Press OK.
    VIN search:
    Select option 1). from the list [Retrieve Part Number]
    FAST II is open. Notice all of the fields are blank and most of the tool bar options are greyed out..
    Click on the VIN field and type in your VIN number and press the ENTER key.
    Note all of the fields are now populated with their respective information.
    Model search:
    Note:
    1) Anything in RED is NOT a valid option. You will get an error if you try to use that combination.
    2) You dont need to fill out all of the fields. You can be general.
    Click the ? and select your model.
    Choose your year.
    Choose your body style.
    Choose you engine.
    Choose your drive type. FWD / AWD
    Choose your trim.
    Choose your suspension.
    Lets Find A Part Number:
    Now that we have our car identified, lets find some part numbers. This process is how to find a part "Visually" rather then directly.
    Select the "Illustrated Index" option from the tool bar.
    Select the category you would like to view. You can also choose multiple categories if you want.
    Select the item you want by left clicking on it. Use the tool bar "Jump" option to navigate between pages.
    Select the "Illustrations" option from the tool bar.
    WOW look at the diagram..
    Move the "LEFT & RIGHT" keys to select the part you would like. Once you hit Enter you can set the Quantity (QTY) and then press enter.
    Once selected it turns RED!
    And now the MAGIC button (F5) or in the toolbar "Translate" which is some SUBARU secret code for PART NUMBER!
    And there you have it! A freaking part number for a EZ30D seal You can see how this system works.
    Parts Description Search.
    I'm not going to go into much detail.. The system works like this: 1st Category is the main search. 2nd is to specify and 3rd is if you need even more detail to describe your search.
    So in this example I will do something as simple as 1st Category "HEAD" and this will give me all the parts associated with the word 'head'. So items like bolts, valves, rockers, etc. will come up in the search..
    Another example: 1st Category "BRAKE", 2nd Category "PLATE" and this should bring up a list associated with Backing Plates.
    Select F3 or Toolbar "Part Name"
    Categories.. Type in what you want. Keep it simple.. BRAKE / HEAD / RADIATOR
    All items associated with the word "HEAD". Left click to add QTY. Right click to subtract QTY.
    Part highlighted. If you want a parts diagram of your item, click the "illustration" button (1). If not you can click "Translate" (2) and you're done.
    Parts diagram: Your part is highlighted in "GREEN" and again you can move left and right and choose a part.
    Done :-D
    Gone and forgotten.
    "Proby" jamal's Avatar
    Dec 2008
    219
    6,967
    55
    Points: 6,967, Level: 55
    Level completed: 9%, Points required for next Level: 183
    Re: Parts Software - Subaru FAST-II 2010 (US/EU/JAP) <--Down
    this is exciting. thanks a lot!
    Dec 2008
    219
    6,967
    55
    also it seems to be working fine for me in 64 bit win 7
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,020
    16,569
    82
    Points: 16,569, Level: 82
    Wow, another amazing post by teh Chuck!
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Quote Originally Posted by jamal
    I get the same runtime error in Win7-Ultimate-x64
    Hmmmm
    Gone and forgotten.
    Dec 2008
    219
    6,967
    55
    unfortunately the jdm stuff isn't working quite right- it froze up on me and is missing the 1st gen impreza.
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    I was waiting for Yamazaki to confirm this... try Win32
    Gone and forgotten.
    MD, USA
    2,613
    17,786
    Points: 17,786, Level: 84
    Community Award
    The Japanese software totally works perfectly. But until I get a model code (full, it doesn't accept partials) for a 1st gen, I cannot confirm that it doesn't have the stuff for them. Without my books, I can only write in all but the last two characters: BC5A4??
    Dec 2008
    219
    6,967
    55
    should be G10, right? It is in the us software.
    MD, USA
    2,613
    17,786
    Community Award
    Considering that G11 and G12 are Imprezas in the J-spec program, I doubt it.
    I just tried it anyway, and it doesn't exist....
    And that isn't the model code I was talking about....
    9,857
    Hmmmm
    Did you try the compatibility mode program? That's always worked for me with older programs & games.
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Yes
    Gone and forgotten.
    SLi Lurker csweston's Avatar
    Feb 2009
    Boise, ID
    392
    5,616
    48
    Points: 5,616, Level: 48
    Level completed: 33%, Points required for next Level: 134
    PC only?
    SLi Resident elislider's Avatar
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    Points: 7,322, Level: 56
    Level completed: 86%, Points required for next Level: 28
    Re: Part # Software - Subaru FAST-2 (US/EU/JAP) <------ Down
    you rock. i just found this thread
    EDIT: except megaupload is gone now, so any chance this stuff can get rehosted?
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    would a newer version contain all content on previous versions? or did they start dropping older stuff as time went on?
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Good question... I can not answer that..
    Gone and forgotten.
    Jul 2009
    Everett, Wa
    1,531
    7,580
    Points: 7,580, Level: 58
    I don't know either but I do know that my local dealership is dropping support for vehicles >20 years old in their software - ie. they have to refer to the paper copy parts list for my 91 Legacy starting this year
    NOOB
    Giggity
    oh boy, thats bad for canada!
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    in a pinch, i'm ok with that, though i do use the parts referencing frequently on opposedforces.com -- but i also have dealer versions of all the physical paper manuals for 95-98 legacy, 93-99 impreza, and a few others in the 00+ range.
    after much fiddling I was able to get one version of FAST2 installed. its tricky to use and I get lost easily in the program, but it does have lots of parts info not available on opposedforces.com
    now i just need to get parallel installs for USDM/JDM/EDM
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Function keys are much faster... You get the hang of it .. think of it like AS400 systems.. tab/F-this...
    I should really post all the links soon.. Just lazy
    Gone and forgotten.
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    i can mirror them for you
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Deal. Please PM and join my dropbox.
    Gone and forgotten.
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    I have been really really busy with getting the tshirts shipped out and my track car but but I managed to finally finish the download links. I have had lots of request recently for these files so here you go SLi. DO NOT LEECH!!!
    Below is a list of *.ISO files that EPC FASTII uses. I am still missing a few so if you have them.. PLEASE send them to me.
    iso broken down like this
    10311LRSF
    [disc][year][month][region]
    [...1.][..03.][...11..][LRSF]
    EUROPE:
    10311LRSF
    10811LRSF
    20505LRSF <-- missing
    20609LRSF
    20701LRSF
    20707LRSF
    20709LRSF
    20711LRSF
    20803LRSF
    20805LRSF
    20809LRSF
    20811LRSF
    30901LRSF <-- missing
    30907LRSF
    31001LRSF <-- missing
    31003LRSF
    31005LRSF
    31101LRSF
    31105LRSF
    31201LRSF
    USA
    10811USSF
    20505USSF <-- missing
    20603USSF <-- missing
    20711USSF
    20803USSF
    20805USSF
    20809USSF
    20907USSF
    21001USSF
    21003USSF
    JAP
    10704SF <-- missing
    10710SF
    20704SF <-- missing
    20710SF
    21004SF
    30706SF <-- missing
    30710SF
    30902SF
    30910SF
    31004SF
    Gone and forgotten.
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    when it comes to the "disc #" part (first digit of the filename) do you need a disc 1, a disc 2, and a disc 3 (example, the most up to date version of each)? or do you just need the newest disc? it would make sense they would release a disc and update it for a while, then release another disc, update it for a while, then another, etc in iterations. but idk if thats how it works. i guess my question is: what is the significance of the "disc number" digit?
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    followup question: is there a way to use the jdm catalogs in the english program? i tried and it doesnt recognize them, so i installed the japanese program separately and it will import the jdm catalogs, but i have no idea what i'm clicking on
    SLi nOOb 96LegacyWagon's Avatar
    Feb 2012
    Metro Detroit (MI)
    163
    2,619
    31
    Points: 2,619, Level: 31
    Level completed: 13%, Points required for next Level: 131
    which version should I get for my 1996 subaru legacy wagon L?
    '87 Buick Electra 187K - Rust in Peace
    '93 Chrysler Town&Country 354K - Rust in Peace
    '92 Dodge Spirit - sold
    '92 Pontiac Grand Am - sold
    '96 Subaru Legacy Wagon L 237K - parting out
    '04 Chevy Impala - new toy
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    any usa
    Gone and forgotten.
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    chuck, didnt answer my questions..
    SLi Supporter
    4,530
    23,515
    Frequent Poster
    Quote Originally Posted by elislider
    no idea. i cant read japanese so I left these for Yamazaki to look into.
    Gone and forgotten.
    Jun 2010
    Portland, OR.
    653
    7,322
    56
    ah, touche
    MD, USA
    2,613
    17,786
    Community Award
    Sorry about that. I just tested them to make sure they work. And they do. I didn't download the English one so I don't know how to merge them.
