[quote=lord flashheart]i ran the stock fuel pump for 6 months with no issues.Originally Posted by "1-3-2-4":1s1r043j
but i would recommend an upgraded pump.
also in the winter if you plan on running 6psi
you will have to turn down the boost in winter because the air is more dense
so you get more air in and the injectors usually cant keep up.
if you are looking to do it on the cheap, you can get a rising rate fuel pressure regulator.
which turns up the fuel pressure to match the boost. the computer doesnt know the difference.
ive done that on some a couple Hondas, toyotas, chevys, and a subaru. they work if you want to
run just a little more boost.[/quote:1s1r043j]I know about the winter air but this is the first I heard of having to adjust for seasonal changes like this, if it's just a matter of finding injectors that will do fine in both winter and summer then it's no big deal to swap them out.
