Page 8 of 8 FirstFirst ... 678
Results 211 to 218 of 218
Thread: DIY: Turbo the EJ25D
  1. #211
    Jul 2013
    Tazewell VA
    740
    4,313
    Points: 4,313, Level: 41
    Re: DIY: Turbo the EJ25D
    Make sure they're 97-99 heads, the 96s combustion chamber is wider than the ej22 bore.
    My 1997 Legacy L
    Fuelly
  2. #212
    t3h ub3r m3mber Garrison's Avatar
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Points: 6,153, Level: 51
    Level completed: 2%, Points required for next Level: 197
    Veteran5000 Experience Points
    I just read through your parts list, you won't be able to run the under-manifold turbo inlet. The ej25d manifold isn't raised high enough to get the pipe underneath. You will have to make your own.
    May i recommend http://www.siliconeintakes.com ?
    They're who I used to build my intake, and their customer service is top notch
  3. #213
    Dec 2009
    Kaysville UTAH
    1,723
    9,426
    Points: 9,426, Level: 65
    Quote Originally Posted by 86bratman
    I've always thought they were as well. I remember the old arguments all over nasioc saying the 251 heads flowed better because the engine had more mid range torque than the 25d. nobody gave any credit to the higher compression or ecu tuning differences between the two.
    Word.
    the problem with the 251 heads is the shortside radius. They dont have one lol.
    the 25D has a couple draw backs like the shrouding around the valves in the combustion chamber. But if you unshroud them a bit you would be amazed at the flow increase. i honestly think if someone was willing to pay me to build a 25D the right way i could hit 240chp N/A. But unfortunatly all my customers want to build 251s instead.
  4. #214
    Jul 2013
    Tazewell VA
    740
    4,313
    I believe we should have a chat sometime.
    My 1997 Legacy L
    Fuelly
  5. #215
    "FNG" KristjanJohann's Avatar
    Sep 2008
    Iceland
    61
    5,998
    Points: 5,998, Level: 50
    Level completed: 24%, Points required for next Level: 152
    I have a problem with what to do with my breather lines, crank case/PCV, IACV and valve cover breathers! I've already connected them into my custom intake but the car is smoking alot of oil and I'm getting oil in my intercooler
    Subaru Leone '86
    Subaru Legacy GX '91 EJ20T
    Subaru Legacy GX '98 EJ25D
    Mazda 626 '81 2.0
    Suzuki GSX-R 750 '90
    ICELAND <3
    Flickr: http://www.flickr.com/kristjanjohann
  6. #216
    Apr 2014
    7
    630
    12
    Points: 630, Level: 12
    Level completed: 60%, Points required for next Level: 20
    I just read this, I'd be interested in turboing my 99 Outback with EJ25D, 4EAT. I replaced head gaskets with FelPro late last year.
    Without engine management, and stock fueling other than pump, I'm seeing 7psi as reasonable. Is this correct? Additionally, an Ebay WRX header/uppipe like this: http://www.ebay.com/itm/STAINLESS-MANIF ... c1&vxp=mtr should clear my water pump.
    Is all of this correct?
  7. #217
    SLi O.G. anothernord's Avatar
    Sep 2008
    Ft. Collins, CO
    2,027
    16,569
    82
    Points: 16,569, Level: 82
    The lower the safer but 7 is about the limit for the stock injectors.
    Yep, that header looks fine. Same one as I used to run with the stock water pump.
    As far as breathers:
    IACV needs it's own line. Crank and valve cover technically be plumbed to separate ports on the intake, but the car will run with them teed together.
  8. #218
    SLi nOOb BDAlex95's Avatar
    Mar 2013
    Bellevue, WA
    138
    3,588
    37
    Points: 3,588, Level: 37
    Level completed: 59%, Points required for next Level: 62
    Quote Originally Posted by anothernord View Post
    Sorry to bring up a dead thread, I just finished building my hybrid with a vf11 on it and I'm having idling issues. You said that the IACV needs it's own line to the intake, but in your picture it looks like you've got all the lines tee'd into each other. I have all the lines tee'd into each other and kept getting a CEL for the IAC. Should I try and reroute my lines to have the IACV seperate from the PCV and crank vent? I can get a picture of my routing later if that would help.
    My greatest feat with my car is the constant willingness to keep it on the road for no apparent reward.
    98 BD 2.5GT EJ22DET(Aiming for the 300hp club!)
    89 S13 240SX KA24E(Blown)
