Page 1 of 2 12 LastLast
Results 1 to 30 of 51
Thread: turbo build info
    Apr 2010
    562
    5,372
    Points: 5,372, Level: 47
    Level completed: 11%, Points required for next Level: 178
    Veteran5000 Experience Points
    turbo build info
    so i just found a complete Ej20 with all accessories including turbo TD04 and 5 speed transmission. with a 30 days warranty with ECU and i believe the intercooler, shipped for 4Gs. has 72K on it
    ive been reading up on doing the swaps, and this should be all plug and play into my 01 leggy for the most part.. correct?
    will i also need the rear diff?
    Apr 2010
    562
    5,372
    Re: wrx swap
    or i could go after a STi engine from an 05 with low miles, missing the turbo. intercooler, tranny etc..
    Apr 2010
    562
    5,372
    Re: wrx swap
    and should i get the cross memeber too orr....?
    SLi Lurker Bookem's Avatar
    Dec 2008
    Moorhead, Mn
    314
    7,238
    56
    Points: 7,238, Level: 56
    Level completed: 44%, Points required for next Level: 112
    Re: wrx swap
    Is your car a 5mt or 4eat? If auto then obviously clutch pedal and lines, if it's a 5mt I'd leave it in there so you wouldn't have to change the rear diff. Wiring is a little bit more than plug and play unless you have someone like East Coast Swappers do it for you. I'd pass on the crossmember, just notch it the then reinforce with clearance for the uppipe.
    SLi nOOb mshriver's Avatar
    Nov 2006
    Western MD
    123
    6,839
    54
    Points: 6,839, Level: 54
    Level completed: 45%, Points required for next Level: 111
    Re: wrx swap
    1. That is a lot of money for an ej20
    2. You need whatever rear end matches the tranny
    3. sti is completely up to you depending on price comparo. But figure about $1000 for a sti turbo and intercooler
    4. You need a turbo cross member or will need to notch yours for the exhaust
    Dec 2008
    Moorhead, Mn
    314
    7,238
    56
    Re: wrx swap
    WRX swaps are going up in price as JDM stuff is not as accessible, and less lower mileage complete (turbo, tmic, harness and ecm) 02-06 wrx's that aren't blown up or already stripped. But if his car is still running mind as well wait to find a better deal, I'm sure there are some to be found, just not the $2k like they were three years ago.
    Nov 2006
    Western MD
    123
    6,839
    54
    Re: wrx swap
    ej205s are a dime a dozen now. for $4000 you could easily buy an entire car and pull the motor and anything you want then sell the rest
    Nov 2006
    Western MD
    123
    6,839
    54
    Re: wrx swap
    oh and I forgot to mention this is far from plug and play. you will need the wiring harness that matches the engine not just the ecu. Then you will either need to merge the wiring yourself if your good with that kind of thing (nightmare). Or have it done, look into iwire, they are very good and do it for about $600, which is cheap compared to others
    n00b 4 Life GTDrifter's Avatar
    Dec 2007
    Dearborn, MI
    1,928
    15,663
    80
    Points: 15,663, Level: 80
    Level completed: 63%, Points required for next Level: 187
    Re: wrx swap
    For 1k more you can get a jdm front clip off rs25...engine trans writing harness etc
    SLi Resident mycargoesvroom's Avatar
    Madison, AL
    645
    4,881
    44
    Points: 4,881, Level: 44
    Level completed: 66%, Points required for next Level: 69
    Re: wrx swap
    If you're serious about a swap you should buy a whole car to pull parts from other wise you'll find yourself being nickle and dimed on stuff you didn't think to buy. A whole car can be had for around what that motor is going for, so I'd stay clear of it.
    Apr 2010
    562
    5,372
    Re: wrx swap
    think a WRX or STi motor..? and are there huge differences?
    Madison, AL
    645
    4,881
    44
    Re: wrx swap
    If your pocket is deep then I say go STI.
    Dec 2007
    Dearborn, MI
    1,928
    15,663
    80
    Re: wrx swap
    can't you do more with a wrx engine? i heard more mods or something of that sort
    Apr 2010
    562
    5,372
    Re: wrx swap
    everything STi is mad expensive.. so i have the money now.. but the questions is, will i have it when it breaks down the road lol. i think a WRX set up would be just as fun in my leggy.
    i was considering that set for 4gs i mentioned earlier, and going through the motor, cams, new turbo, intercooler etc.
    Apr 2010
    562
    5,372
    Re: wrx swap
    but i also like the route of buying a crashed car, just so ill have all the parts
    Madison, AL
    645
    4,881
    44
    Re: wrx swap
    I think for the money you can't go wrong with the WRX swap. Find a wrecked car so you have everything you need right there and you can sell off anything you don't use to re-coup some of the investment.
    SLi O.G. httrdd's Avatar
    NEPA
    2,700
    11,761
    Points: 11,761, Level: 71
    Re: wrx swap
    Think about all the other parts you can use on a parts car too! Brakes, scoop, tranny, springs/struts, interior..........
    TJ
    99 LGT H6 Limited OBP
    Nov 2006
    Western MD
    123
    6,839
    54
    Re: wrx swap
    ^ or part it out and make a good chunk (if not all) of your money back.
    I wish I had a whole parts car for my swap, but I just couldnt pass up the deal I got on mine
    t3h ub3r m3mber Garrison's Avatar
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Points: 6,153, Level: 51
    Level completed: 2%, Points required for next Level: 197
    Apr 2010
    562
    5,372
    Re: wrx swap
    oh shit! thats bomb, i need a tranny too tho.. can you run a 5spd with an STi motor? or can i only run the 6?.. cuz a tranny, turbo, exhaust and all those others parts is going to be at least another 2500/3000..
    "FNG" Magoozle's Avatar
    Dec 2008
    57
    4,983
    45
    Points: 4,983, Level: 45
    Level completed: 17%, Points required for next Level: 167
    Re: wrx swap
    How mechanically inclined are you? Or with wiring for that matter? Just curious because I have seen a lot of people with good intentions of swapping but end up selling for a myriad of reasons. Just know what you are getting yourself into. Might be easier to buy one already done. Just my 2 cents.
    Nov 2006
    Western MD
    123
    6,839
    54
    Re: wrx swap
    Quote Originally Posted by jewbaru
    Tranny alone with be over $3000
    Luckily any subaru engine / tranny combo work together. The sti 6 speed is just a lot stronger and geared lower
    13,384
    Re: wrx swap
    Oh. WOW. You need to hold onto your cash for about a year and do some real research, not just hit the post thread button... Read over a few MR1 threads - several times. Read the swaps faq, the stickied threads and the successful swaps. Call up shops in your area or time zone that have done this work and ask them what would be involved and the cost.
    30 day warranty means bugger all if you can't complete the swap in a day - every day you have with the engine and it's not running means you lose a day off your warranty.
    Apr 2010
    562
    5,372
    Re: wrx swap
    ok.. so i dont think this swap is going to happen after listening to huffer and doing research all last night, all these WRX parts are a little too expensive and seems like fitment for me for this swap wont happen over a long weekend lol
    so in the time being, ive found two different 2000 legacys
    ones a GT 5spd fully loaded with 183K, rust over each rear wheel, needs tires, guy wants 3900
    other is an L, 5spd, CLEAAANN inside, 138K, rust over each rear wheel, new tires, guy wants 2200
    i figure, buy the car cheap, use the left over insurance money to rebuild the motor with turbo pistons, new crank etc. and then sell one car for a turbo set up, and sell the other for body/paint work
    my question is.. go with the high milage GT, get the leather and everything.. orr save a little extra money, sacrafice the sunroof and leather for the cheaper car, and spend the other 4k i have left on the rebuild and turbo set up...
    ORRRRRRR, i found a turbo WRX, with brand new paint and tires, with 180+ for milage, and the guy said he'd do it for 5gs
    Apr 2010
    562
    5,372
    Re: wrx swap
    too many options and i need advice lmao, i REALLY like the GT with the leather and sun roof... but if i buy the other one for 2200 ill have plenty of money left over to mod the shit out of it, and the L is dark blue, so when i paint it world rally blue i wont have to worry about jams or a value shade
    but idk if the GT would be a better base for a turbo set up.. and IT HAS A SUNROOF lol
    Apr 2010
    562
    5,372
    Re: wrx swap
    Quote Originally Posted by Magoozle
    when it comes to subaru, im pretty good with a wrench. im just not sure on the fitment issues, im not a good fabricater, and i would have someone do the wiring for me, cuz i cant follow a wiring diagram for the life of me haha, but when i start something, i finish it. but i dont know if ill have the money to afford to finish it lmao
    but if you read my above posts, i think i might just buy a 5spd leggy, and turbo the motor
    13,384
    Re: wrx swap
    If you're looking to go power, you get the lightest version of the chassis you want to drive. That means no leather, no sunroof. Sunroof's add 100lbs easy. Leather is heavier than cloth interiors. So if you want a good stock base to mod from, you get the lower trim model.
    Here's what you do. Buy the chassis you want. Then spend some money and buy a front clip from a turbo Subaru. STi, WRX, Legacy, FXT. Choose your flavor.
    Then start working on tracing the wiring for the engine harness for the engine to the corresponding wires on your existing harness (in the car you're driving). When you have that figured out then the hard part is just making sure you have the hardware needed to swap the engine in. Basically, if you have a front clip you can use the engine cross-member from the donor car, along with the entire engine and the exhaust/intake components. The only thing that will be needed after that is to swap ECUs and fab up the exhaust.
    Your stock tranny will be "ok" unless you hammer it.
    Dec 2008
    57
    4,983
    45
    Re: wrx swap
    Having owned a fair amount of Subaru's both swapped and not. Take some time to think about what you really want. Do you want a track car? Do you want a fun cruiser with power? Do you want power and reliability? Lots of different answers for each of those questions. Even swapping a car correctly is still not as reliable as a car that came from the factory that way. If you want a project though, then I say go for it and enjoy learning the ins and outs of every part of your car. If I could do it all over again, I would buy an Impreza RS and swap it with a full STi drivetrain, good amount of power and enough reliability for me to be able to drive cross country if need be. Or even a Legacy GT with full STi swap. I personally don't like picking a lower model and building it up, Im doing that at the moment and its a far bigger pain in the ass than I had anticipated.
    Nov 2006
    Western MD
    123
    6,839
    54
    Re: wrx swap
    Im confused. Do you currently not have a car?
    Buying a new legacy and turboing a NA engine is an even worse idea then trying to do a wrx swap without knowing what your doing. My 2 cents is buy a wrx or even look for an 05+ GT. Ive seen them in the 6-7k range.
    If you want to swap / turbo a car that did not come that way here is a good way to do it.
    1. Buy either a swap or complete parts car
    2. Do whatever you want to the engine and have it all pretty and on a stand ready to go in the car before you touch your car.
    3. Buy a legacy wiring harness for the same year and model as yours.
    4. Send the swap harness and your legacy clone harness to iwire, ecs, etc.
    5. Have everything ready to go in the car.
    6. Then bust everything out in one weekend..... No downtime
    Apr 2010
    562
    5,372
    Re: wrx swap
    I currently have two leggys. Both running. Both auto. Ones an L. Ones a 35th anniersary
    I NEED a 5 speed cuz I'm going crazy.
    So I'm goin to drive one of the autos while i plan on taking the 5mt motor and sinking a lil money into it so it's turbo ready. New pistons. Crank. Rods. Bearings. Etc
    New clutch. Install. Get it driving. Sell both auto leggys. Take that cash and buy my turbo n intercooler n zaust set up
    No wiring nightmare. No crazy fabrication. Close to "stock" as possible with a built motor and turbo
