And instead of showing you it, I'll show you things I've broken with it already:
Luckily it was nothing too valuable. Although it scares me that I was able to break an impact socket adapter without the use of power tools.
Gotta lay off the 'roids duder.
Does your hulking mass make it difficult to work inside the engine bay?
It's such a challenge, actually.
Finding XXXXXL shirts is also hard.
That's the thing, I'm not even that big or strong. But that stupid impact socket adapter just snapped when I was trying to undo the bolts for the struts. I wasn't even using an impact socket, it was just a standard Kobalt one from my set.
Oi vey, that blows. Do you know what grade steel the material was? Maybe Snap-on has something you could pick up
You should hear the horror stories I've heard about breaking loose a crank nut on a Honda engine.The guy telling the story said he needed to brace the block against the wall with a fork-lift, and use a breaker bar with a 6' extension on it, and push that extension down with a freaking tractor bucket in order to bust it loose. The nut is torqued to something like 245ft/lbs.
At least subaru isn't -that- retarded.
You shouldn't be that surprised.. I have a habit of snapping standard sockets with just a 6" extension and a standard ratchet. Same goes for the other way around.. breaking the ratchet instead of the socket..
Good thing I buy Life Time Warranty tools :-D Yay MAC
I break rusted shit all the time on my car. I even crack impact sockets (harbor freight ones) . Lol. I have the same breaker bar that is use to pry and lift stuff. Pretty damn durable.
TJ
99 LGT H6 Limited OBP
Originally Posted by chuckthefuk
