So I may just be the shortest term member ever to be at sl-i if this does not get resolved. Here is the story, I allowed my brother to take my car because his jeep was in the shop. Upon returning to my house with my car he was driving through the parking lot into the sun and drove dead center into a concrete light post. The radiator and fans are smashed. Radiator support is toasted and i have a pulley pushed into the timing belt cover. The engine should be fine but the radiator support im not so sure of. I was able to get things torn down a little to asses the damage. I stopped when i saw the timing belt cover. Tomorrow i will pull the crank pulley and check under the cover. The radiator support is available but has anyone ever replaced one. This thing is welded and bolted in place and im not sure its possible to salvage. If anyone has any advice how to remove the old one and or suggestions how to install the new one would be greatly appreciated. It was dark before i could take pictures so tomorrow I will upload so you can see. If the motor is done for then that wrx swap might come sooner then i thought it would. Thanks, Tim
