Results 1 to 27 of 27
Thread: DIY: Heater core replacement in BD/BG/BK
    5,050
    Yes, I was dumb enough to actually do this on my own car...
    Difficulty level 1-5
    5 for pain in the ass!
    I decided that after year of the slight smell of coolant and the windows starting to fog, it was time to change the heater core out. I have had a new one sitting in a box for the last few years...
    If you are a beginner, DO NOT try this! If I wasnt short of work and had the money to take it to the dealer, I would have in a heart beat!
    REMOVE BATTERY TERMINALS and cut all power to car!!!!I dont want to hear that an airbag blew in your face....
    Started at 10AM... 10:00 hours to you military guys... Let it begin!
    Removed front seats... Move room to work.. If you dont already know how to take out the seats, put the tools down and stop right now!
    Pull the center console... 9 screws...
    If you dont know how, this is the shifter release...
    Pull stereo bezel... 2 ash tray screws and cup holder screws... unplug cig lighter...
    Remove stereo... Dont forget about the screws way in the back....
    Vent trim... Pull out easy... unplug 4 ways switch...
    Glove box... 2 screws at bottom, then remove inner backing plate...
    There is a few 10mm bolts in there...
    Remove cluster bezel... 4 screws... remove switches... I had to cut the wires for my alarm light, thank you so much Subaru America for HARD wiring my damn light!
    Remove Cluster... Unplug everything, there are 4 plugs if I remember right...
    Remove 4 screws for HVAC
    Pull the lower dash cover... 2 screws...
    5,050
    Re: Heater core replacement in BD/BG/BK PIC HEAVY!
    Time for the dash... :smt009 I'm sure I missed a few here, but you will get the point...
    Top cover is tricky... It's better to damage the little cover then the dash. Use something flat to pull up, do not pry up as it will damage the dash pad...
    Cover removed... 2 10mm bolts...
    There is one of these on each side of the dash... 10mm bolts...
    Remover steering column bolts... 2 12mm... (Also no pic, remove column shaft bolt on rack)
    The dash should now be free.... Time to unplug a butt load of stuff!
    Passenger Airbag needs to be unplugged... MAKE SURE THE BATTERY IS DISCONNECTED!!!!
    A pile of plugs on driver side... Also the HVAC, Stereo, and other random things...
    This is what you should have out....
    I opted to have the HVAC unit still hooked to the car, or heater box...
    Dash should be ready to be pulled... now time to remover the cross bar... 4 12mm nuts and bolts of driver side, 2 12mm nuts on passenger side. 2 10 mm nuts behind Airbag Control unit, 4 security bolts for ABCU...
    Now for the hardest part! You think I'm joking huh.... Yeah, no joke getting the box off the fire wall is crazy hard! There are a few 10mm nuts and bolts that hold all the boxes to the fire wall. This is where I kinda gave up on pics and procedure. It is ether glued to the fire wall, of the fire wall insulation melts and holds the heater box to the wall. This makes it really hard. I left the AC box alone since I have no need to service it at this time and thats more money.
    The glued stuff....
    One split heater box...
    And the new core... You remove the pipes from the core and reinstall...
    Ok... So if you have really got this far, you can figure out how to put it back together. In truth, it goes back together much easier then it comes apart. If you have a Dealer installed alarm, know that you will be cutting a few hard wired wires. This is a big job and I worked on it for about 9 hours with only a short 30min brake.
    This is a job that you can do, but at your own risk! Hope this helps someone...
    SLi nOOb krot84's Avatar
    Mar 2010
    ISRAEL
    133
    4,714
    43
    Points: 4,714, Level: 43
    Level completed: 82%, Points required for next Level: 36
    Thanks and good luck man!! That's exactly what i was waiting for.
    And you're not dumb you're just an enthusiast like all of us
    Hopefully your DIY will give me the courage to do it myself.
    '08 B4 2.0R 4EAT
    5,050
    Thanks... Like I said, if I had the money to take it to the dealer, I would. This is a big job. As of now, everything is working like it should and completely finished.
    If you do decide to do this, make sure you do this in one day, if you dont, you will forget a lot of things. I started to forget by the time I was starting to re-install everything.
    Mar 2010
    ISRAEL
    133
    4,714
    43
    At least i don't have to worry about an air bag exploding in my face 'cause i don't have any. LOL
    '08 B4 2.0R 4EAT
    5,050
    Huh?! Do they not have then over there?
    Mar 2010
    ISRAEL
    133
    4,714
    43
    I think they were just playing cheap when the car was imported, the same with the awd, my car is fwd. go figure...
    Another thing, why did you remove the center console and the sits ?
    '08 B4 2.0R 4EAT
    5,050
    Taking out the seats and console gave a LOT more working space that you will need. Also the dash needs lots of space to come out. It's only a little more work to make your life that much easier!
    SLi Resident eekay's Avatar
    Apr 2009
    Denver, CO
    789
    7,548
    57
    Points: 7,548, Level: 57
    Level completed: 99%, Points required for next Level: 2
    Awesome! Great DIY, Dead91! I'm glad you decided to do it.
    t3h ub3r m3mber nikolaus.conrad's Avatar
    Jun 2010
    Finger Lakes/ Rochester NY
    1,622
    9,726
    Points: 9,726, Level: 66
    Level completed: 19%, Points required for next Level: 324
    5000 Experience PointsO.G.Social
    I needed to do this for my first Subaru, I tore apart a car at my junkyard to get the core, such a pain in the ass. Then a few days later someone hit me and totaled it
    -Nick
    Quote Originally Posted by Thomistopheles
    The EJ25D likes to blow its head gaskets in a spectacular manner, leaking combustion gasses into places it's not supposed to go; giving you the world's worst tasting milkshake.
    9,857
    Great DIY!!
    I'll add this to the threads of note.
    One little warning for everyone: Do not disconnect the sleeved cable that is used to control the heat/cool air at the HVAC controls side - it's impossible to get back on without breaking things. The OP didn't disconnect anything here, but if you want the HVAC controls out of the way, disconnect the cable at the heater manifold style (under the dash). It's much easier to reconnect.
    I made the above mistake when I took apart my HVAC controls to do lights.
    Apr 2009
    Denver, CO
    789
    7,548
    57
    Are you talking about the E/C clips that connect the temperature selection slider on the HVAC? I've disconnected this before, but never under the dash. I'm going to have to pull all this stuff apart soon though. So, I suppose I'll find out! Thanks for the heads up.
    5,050
    Yeah, if you do pull the HVAC unit, take it off the box if you need to. So much easier, but only if you have to. I left it as it was less work and less parts to miss place! hahaha...
    And thanks guys... I'll work on a few more if I have the time. Next big on is the headliner in my BH and also in my BD... sigh....
    SLi Resident grayguy's Avatar
    Mar 2007
    Duluth, MN
    940
    10,233
    67
    Points: 10,233, Level: 67
    Level completed: 46%, Points required for next Level: 217
    where do you buy that stupid ABS module socket? I've always just taken them out with vise grips.
    1998 Legacy 2.5GT: Stock to turbo to stock, and given to my Dad, then to my sister that blew it up. Now I've repo'd it and it will once again rise to former glory!
    5,050
    haha! Harbor Fright has a cheap ass set I got for like 6 bucks (looked at 5 sets before finding a complete set that was drilled straight). All they are is security torques. I'll get a nice set someday, but they come in handy.
    Apr 2009
    Denver, CO
    789
    7,548
    57
    ABS module socket?! Pics?
    Mar 2007
    Duluth, MN
    940
    10,233
    67
    I am fianlly gonna do this to my car this weekend. Super not looking forward to it. But alas, so much cheaper than paying for it
    "Proby"
    Mar 2012
    San Jose, CA
    235
    4,606
    43
    Points: 4,606, Level: 43
    Level completed: 28%, Points required for next Level: 144
    Would you go over details how to disconnect that AIRBAG yellow/green connector? I always fought with it and never could get it out. Push the yellow connector down, slide it to the left?
    03 350Z - 120K DD
    99 RS - Currently swapping JDM V9 207
    98 RS - 145K JDM 20K V4 WRX
    02 WRX - 150K DD
    95 Legacy Wagon - 200K Winter Tahoe tank
    5,050
    If I get some time and also get well from being sick, I'll see if I can take some pics or take a vid.
    I completely forgot I even did this DIY... haha
    "Proby"
    Mar 2012
    San Jose, CA
    235
    4,606
    43
    Get well and thanks the DIY video coming later.
    03 350Z - 120K DD
    02 WRX - 150K DD
    Mar 2007
    Duluth, MN
    940
    10,233
    67
    Well, today was the terrible day. I have just over 3.5 hours into pulling the dash/blower box/heater box, replacing the core and blower motor, swapping the dash harness onto a new dash, and reinstalling it all. I think I'll have about another hour into it when I got back tonight to hook the harness all up and put it back together.
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
    "FNG" Patrick Olsen's Avatar
    Aug 2009
    Where the Navy sends me...
    51
    5,822
    Points: 5,822, Level: 49
    Level completed: 36%, Points required for next Level: 128
    Excellent write-up. I just pulled mine out, and figured I would add a couple pics to fill in where you gave up on pics.
    Quote Originally Posted by Dead91silvia View Post
    After I drained the cooling system, I pulled the heater hoses off the hard lines at the firewall, and then I stuck a couple of vacuum caps backwards into the hard lines to seal them and keep any residual coolant from leaking out inside the car:
    As you said, only 3 bolts/nuts hold the heater box in place, and there's a harness to unplug on the driver side:
    Like you, I found the heater box did NOT want to pull away from the firewall. I was pulling and prying, but something seemed stuck. Kind of on a whim, I took a can of spray silicone lubricant (which is great for breaking loose things like old rubber exhaust hangers) and sprayed that on the hard lines and the firewall seals in the engine bay. Went back in the car, pulled on the heater box while rocking it back and forth a bit, and it came right out. So I think in my case what was holding the thing in place was the rubber firewall seals being stuck to the hard lines.
    Edit: When I went to actually pull the heater box out of the way completely, I found that there is an additional harness to worry about, located lower on the heater box than the harness I showed before. In this case, the harness is mounted to the box, so you remove it by removing the phillips head screw in the 2nd picture:
    Pat Olsen
    '97 Legacy 2.5GT sedan - RCE Tarmac2 coilovers, 4-pots front, H6 rears, '06 STI 6-speed, Quaife rear diff, mAd N/A powah!
    Aug 2009
    51
    5,822
    I pulled the heater core just to get access to the wiring, but now that I have it out, I'm wondering if I should go ahead and replace it. Part of me thinks, "If it ain't broke, don't fix it," but part of me thinks the car's got 240k miles or so on it and I might as well swap the thing out while I'm here.
    For those that have done this, what replacement heater core did you use? I see the OEM one (72130FA002) lists for $317 (), while aftermarket ones are available on Rock Auto for under $50. I'm all for using OEM parts, but that price difference is pretty ridiculous.
    Pat Olsen
    5,050
    Nice! I just got fed up with taking pic and I wanted to get it done when I stopped snapping pics... haha... The core I installed was about $79, but I also got it back in like 2008 and it sat in a box for years.
    "FNG" Michelle's Avatar
    Feb 2015
    55
    2,173
    28
    Points: 2,173, Level: 28
    Level completed: 16%, Points required for next Level: 127
    Disconnect battery, he says. Hmm...
    Kidding. This is a great thread. I may need to reference this later if I do a harness merge. And thanks, Patrick, for the tip about the silicone! I've been following your thread on corner-carvers!
    SLi Lurker meepers's Avatar
    Sep 2010
    Phoenix, AZ
    423
    5,843
    Points: 5,843, Level: 49
    King of Publishing
    Quote Originally Posted by Michelle View Post
    That right there is GOLD!
