I decided to make another thread for my car for a few reasons. Clutter, dead pic links, information all over the place.
~Current Mods~
Drivetrain Performance
-High compression engine EJ22 Heads EJ25 Block
-Cometic hybrid EJ22/EJ25 head gaskets
-OBX CAI (wrapped) w/AEM Brute Force 9" air filter and hydro shield
-OBX Dual port UEL header (wrapped)
-Custom 2.5" stainless steel cat back (Made by Wicked Innovation)
-Custom 2.5" "J" pipe cat section w/2 Magnaflow high flow cat's
-Delta cam regrind
-Megan N1 style muffler
-NGK Iridium spark plugs
-MSD ignition coil pack w/4Zero1Motorsports mounting plate
-Magnecore spark plug wires
-Deatch Werks 255LPH fuel pump
-Subaru 500cc fuel injectors (clean and rebuilt)
-Parallel fuel mod (in progress)
-Koyo Radiator
-GrimmSpeed 160 T stat
-Mishimoto gauge radiator cap
-OBX Silicone radiator hoses
-STi engine mounts
-STi tranny mount
-TiC cross member bushings
-TiC shifter pivot bushing
-Kartboy front shifter bushings
-Kartboy rear stay shifter bushing
-Competition Clutch Stage 1 clutch kit
-Perrin short shifter
-GRIMMSPEED thermal coated PnP 2.5L throttle body
-GRIMMSPEED thermal coated PnP 2.2L intake manifold
-GRIMMSPEED Intake manifold phenolic thermal spacers
-Throttle body coolant bypass
-Group A throttle body spacer
-Group A pitch stop
-"Top secret " LWC pulley
-Gates Racing micro V belt
-Dimple magnetic drain plug
-A/C delete
Suspension/Handling
-JDM BG5 Bilstein struts
-JDM BG5 STi pink springs
-JDM Aluminum control arms (TBI)
-Cusco Rear lower arm brace
-Juron front strut brace
-Whiteline steering rack bushings (TBI)
-GroupA front end links
-Outback 18mm Rear sway bar
-GroupA rear diff locking bolts
-Falken tires
-Muteki lug nuts
Brakes
-04 LGT Calipers
-04 LGT DBA street series rotors
-04 LGT Hawk HPS pads
-04 LGT 4Zero1Motorsports ss brakelines
Exterior
-JDM Front bumper
-JDM HippoSleek side skirts (TBI)
-JDM Clear side markers (TBI)
-JDM Folding power folding heated mirrors
-JDM Tail lights
-JDM mud spats (TBI)
-JDM trunk lid (Red LED 3rd brake light)
-JDM Projector foglights
-JDM Projector headlights
-JDM aftermarket grill (TBI)
-Rear GT skirt
Lighting
-6000k HID kit
-White L.E.D. License plate lights
-Amber L.E.D. directionals
-White L.E.D. reverse lights
Interior
-Sony GPS
-MOMO STi v7 Steering wheel
-STi eBrake handle (TBI)
-Stainless steel gauge cluster bezel (TBI)
-White LED doom light
-White LED map lights
-White LED glove box light
-GT rear deck cover (3rd brake light delete)
Random stuff done to it recently:
Lucus power steering fluid
Wix fuel filter
Dual exhaust port 2.2 SOHC (Machine shop cleaned)
IDLER PULLEY (2)
ADJUSTER ASSEMBLY & BELT TENSIONER
REAR MAIN SEAL FOR 1990-2009
O RINGS
CAM SEALS
CRANK SEAL & LOWER SLING
TIMING BELT
GATES WATER PUMP ASSEMBLY & GASKET
COVER OIL SEPARATOR KIT with bolts
VALVE COVER GASKET KIT (both sides and six grommets)
Redline 10w-40 Oil and K&N oil filter
NEW FUEL SENDERS
--------------------------------LATEST UPDATES------------------------------
GT hood
Just realized I am well over 200k, not 100k![]()
BEFORE I BOUGHT IT
CURRENT STATE (new pics to come)
Lowered on JDM BG5 specific STi springs and Bilstein struts.
JDM steering wheel w/modded cruise control switch from the original steering wheel
Custom SS exhaust
Walbro fuel pump and new OEM fuel senders
Delta cams
JDM RS trunk lid (some day will be painted)
GrimmSpeed PnP throttlebody
GrimmSpeed PnP intake manifold
Muteki lug nuts
Kart boy bushings
Multi tasking, I miss my bike...
I believe this pic is from the summer of 2011
