I'll try to organize this as best I can, but I'mma slap it all up now, and edit this post later, okay?
EDIT: 1.35pm, thursday afternoon: For those of you who don't know, the weather here in Western Washington is indescribably wonderful. I'm off work as of 35mins ago, and I'm headed home to bask in sun, and play with myself. Hot weather makes me hot, too.
Okay, here we go:
http://www.surrealmirage.com/subaru/ is a good start, and so is
http://www.surrealmirage.com/subaru/fil ... Sheets.pdf
SOURCES: http://www.graphics.cornell.edu/~v/partnumbers.html ,
http://bbs.legacycentral.org
Various part #s, may be duplicates, as I'm Copy/Pasting:
Coolant Temp sensor: 22630AA041
Updated Knock sensor: 22060AA031
MT, Diamond Coil Pack: 22433AA370
AT(black), MAF sensor: 22680AA160
AT, Idle air control valve: 22650AA034
Oxygen sensor: 22690AA150
Throttle Body gasket: 16175AA150
AT pan gasket: 31397AA040
ATF add-on filter kit: 31099AA091
Oxygen (NA) 22690aa150 91.40
ball joint left 21067ga050 25.36
Timing belt 13028AA102 $63.43
Turbo/NA water pump 21111AA026/21111AA007, both $88.82
Thermostat 21200AA072 $14.03
Front crank seal 806733030 $8.83
Exhaust manifold gasket 44022AA020 $9.53
"16 VALVE" sticker 91531AA630 $30.80
PCV valve 11810AA000 $12.38
4WD nonturbo throw-out bearing 30502AA051 $34.95
4WD nonturbo throw-out bearing clip 30539AA000 $2.28
4WD nonturbo Clutch fork dust boot 30542AA000 $23.90
4WD nonturbo Clutch fork 30531AA110 $25.12
Bellhousing rubber cover 11413AA033 $5.38
90-91 nonturbo front bumper cover 57720AA010 $239.97
Nonturbo exhaust flange gasket 44022AA062 $7.98
Axle-back gasket 44022AA211 $8.63
Axle-back bolt 901660014 $1.19
Axle-back nut 902350001 $1.74
STi exhaust hanger ST440314S000 $9.95
Turbo rear swaybar bushings 20401FA021 $4.82
3-nipple PCV tree on block below PCV valve 11821AA221 $12.22
7011AA131 turbo rear LSD
114130151 brake line copper washer
25232AA020 ignition relay
16175AA150 throttle body gasket
22659AA060 IAC valve gasket
36015GA111 clutch pedal pad
623006021 acorn lug nut
28055AA002 lug bolt
22060AA031 knock sensor
22680AA170 aluminum housing hot-wire MAF
G3110AS100 90-91 Calsonic R-134a retrofit kit
G3110AS120 92-93 Calsonic R-134a retrofit kit
G3110AS000 90-91 Zexel R-134a retrofit kit
G3110AS010 92 Zexel R-134a retrofit kit
G3110AS020 93 Zexel R-134a retrofit kit
22690AA161 turbo oxygen sensor
22690AA150 non-turbo oxygen sensor
13028AA102 timing belt
26310AA092 turbo front brake rotor
26310AA112 turbo rear brake rotor
14035aa290 intake manifold gasket
22611AA694 turbo ECU
498307500 select monitor
498347502 90 select monitor cartridge
498348400 91 select monitor cartridge
498347601 90-91 select monitor cartridge
498348800 92 select monitor cartridge
498349200 93-94 select monitor cartridge
498347700 90-94 select monitor cartridge
11126AA000 oil drain plug crush washer
23700AA090 alternator
22012AA020 turbo pressure sensor
21200AA072 thermostat
11044AA282 turbo head gasket
11033AA114 non-turbo head gasket
Thermostat Gasket 21236AA010
Right Rear ABS Sensor 26740AA021
Left Rear ABS sensor is 26740AA031
Pressure Exchange Solenoid 14774AA340
Turbo MAP 22012AA020
22680AA170 aluminum housing MAF
22680AA160 plastic housing MAF
22060AA031 updated knock sensor
22633AA060 throttle position sensor
22630AA041 water temperature sensor
21203AA030 temperature gauge sender
22012AA020 pressure sensor
14774AA341 pressure exchange solenoid
16102AA013 wastegate control solenoid
82501GA240 fuel pump relay
32005AA052 5MT reverse switch
14774AA351 purge control solenoid
42084GA460 turbo auxiliary purge valve
42036AA040 turbo charcoal canister
42036AA000 non-turbo charcoal canister
22611AA564 90-91 5MT non-turbo ECU
22611AA383 90-91 4EAT non-turbo ECU
22611AA933 92 non-turbo ECU
22611AB060 93 5MT non-turbo ECU
22611AB052 93 4EAT non-turbo ECU
22611AB770 94 5MT non-turbo ECU
22611AB760 94 4EAT non-turbo ECU
28055AA002 lug bolt
694005092 lug wrench
26402FA071 single stage brake booster
725042000 brake booster seal
26151AA163 brake booster vacuum hose
26536AA001 brake line banjo bolt
114130151 copper brake line washer
901130011 front caliper bracket bolt
901120036 rear caliper bracket bolt
736016020 brake booster/pedal pin
051108001 brake booster/pedal pin clip
26310AC040 WRX front brake rotor
26471AA032 ABS master cylinder rebuild kit
26471AA010 non-ABS master cylinder rebuild kit
26401AC040 turbo brake master cylinder
26451AA000 brake master cylinder reservoir
26453AA002 brake master cylinder cap
725736010 brake master cylinder reservoir seal
26771AA000 Bosch ABS hydraulic unit
26730AA001 Nippon ABS hydraulic unit
26731AA200 Nippon 2E ABS hydraulic unit
26740AA040 ABS G-sensor
87022AA051 90 5MT cruise control unit
87022AA200 91-94 5MT non-turbo cruise control unit
87022AA320 91-94 5MT turbo cruise control unit
87022AA310 4EAT turbo cruise control unit
87022AA190 4EAT non-turbo cruise control unit
30100AA630 turbo clutch disc
30210AA261 turbo pressure plate
30502AA100 turbo throwout bearing
30620AA021 turbo clutch slave cylinder
30622AA001 turbo clutch slave cylinder kit
30542AA021 turbo clutch lever boot
30546AA030 turbo clutch lever release spring
30620AA100 WRX clutch slave cylinder
ST2031055000 STi front strut top mount
E4010FA000 strut tower bar
927760000 strut mount socket
14035AA290 intake manifold gasket
44022AA170 manifold-to-uppipe gasket
44022AA150 uppipe-to-turbo gasket
44022AA180 turbo-to-downpipe gasket
44022AA160 crosspipe gasket
14038AA000 turbo exhaust manifold gasket
44022AA020 non-turbo exhaust manifold gasket
44022AA122 turbo donut exhaust gasket
44022AA062 non-turbo donut exhaust gasket
44059AA010 midpipe bolt
44044AA010 midpipe spring
802008270 midpipe nut
902370010 exhaust nut, mild
902370029 exhaust nut, stainless
44059AA030 pre-downpipe exhaust bolt
800910340 turbo and uppipe stud
800910390 exhaust manifold stud
012510250 lower downpipe mounting bolt
010110250 upper downpipe mounting bolt
73008AA710 90-91 Calsonic A/C compressor
73011AA091 92-93 Calsonic A/C compressor
73011AA040 90-91 Zexel A/C compressor
73011AA080 92-93 Zexel A/C compressor
73011AA120 94 R-134a A/C compressor
73061AA031 Calsonic evaporator core
73061AA010 Zexel evaporator core
72024AA000 blower motor resistor pack
498307500 Select Monitor
498347502 90 ECU/TCU Select Monitor cartridge
498348400 91 ECU/TCU Select Monitor cartridge
498347601 90-91 cruise/climate Select Monitor cartridge
498348800 92 ECU/TCU/cruise/climate Select Monitor cartridge
498349200 93-94 ECU/TCU/cruise Select Monitor cartridge
498347700 air suspension Select Monitor cartridge
86661FE020 WRX STi intercooler spray bottle/pump
86636FA120 WRX STi intercooler spray nozzle
83001FE020 WRX STi intercooler spray switch
ST165464S000 STi air filter
ST440314S000 STi exhaust hanger
ST4511355000 STi radiator cap
10103AA310 EJ22T short block
ST1231055010 STi flywheel
ST3010055100 STi clutch
15010AA108 turbo oil pump
27011AA131 rear 3.90 LSD
21132AA010 turbo coolant filler tank
45113GA022 radiator cap
807611172 tank-to-turbo coolant hose
21132AA075 WRX coolant filler tank
10100BK600 EJ25T engine assembly
14471AA001 turbo recirculating blowoff valve
46023AA110 turbo compressor inlet rubber elbow
14412AA070 Stock turbo
14412AA080 RHB52 VF12 turbo
14412AA092 TD05-16G turbo
SOA4786010 non-turbo head
SOA4786020 turbo head, right
SOA4786030 turbo head, left
11095AA090 head bolt
10103AA280 non-turbo short block
10103AA310 turbo short block
16611AA150 turbo injector
42021AC024 turbo fuel pump
44033AA002 turbo chimney
047406120 chimney bolt
23300AA220 5MT starter
23300AA230 4EAT starter
44102AA030 turbo downpipe
20100AA120 turbo crossmember
20100AA101 non-turbo crossmember
ST4100055110 STi motor mount, right
ST4100055120 STi motor mount, left
16611AA231 STi injector
22650AA034 90-91 AT and 92-94 non-turbo IAC valve
22650AA050 90-91 MT non-turbo IAC valve
22650AA111 turbo IAC valve
11140AA046 oil dipstick
31100AA521 turbo torque converter
31100AA552 non-turbo torque converter
22670AA050 fuel pressure regulator
SOA925H500 FWD CV axle
SOA925H600 4WD front CV axle
28044AA000 axle nut
051906452 axle spring pin
28015AA070 outer front hub seal
28015AA021 inner front hub seal
22433AA400 later Diamond coil pack
22433AA360 4EAT and/or turbo coil pack
22433AA370 5MT non-turbo coil pack
809218140 alternator and power steering belt
73013AA000 air conditioning belt
42072PA010 fuel filter
42031AA040 fuel filter rubber padding
42053AA000 fuel filter mounting band
42050AA020 fuel filter bracket
16546AA020 air filter
901120059 air filter housing bolt
15208AA060 oil filter
803926040 manual transmission drain plug gasket, aluminum
803926070 manual transmission drain plug gasket, copper
22401AA310 spark plug
11810AA000 PCV valve
90815AA380 92-94 turbo hood blanket
90814AA000 hood blanket clip
21111AA007 non-turbo water pump
21111AA026 91 turbo water pump
21111AA065 92-94 turbo water pump
21114AA050 water pump gasket
11060AA060 turbo thermostat cover
11060AA070 non-turbo thermostat cover
21236AA010 thermostat cover gasket
SOA635002 factory coolant, 1 quart
SOA868V9210 factory coolant, 1 gallon
13294AA012 valve cover gasket
13271AA051 valve cover bolt grommet
64620AA020ML manual seatbelt, right
64620AA030ML manual seatbelt, left
64610AA220ML lap belt, right
64610AA230ML lap belt, left
62180AA000ML right front inside door handle plastic cover
62180AA010ML left front inside door handle plastic cover
62180AA020ML right rear inside door handle plastic cover
62180AA030ML left rear inside door handle plastic cover
84931AA130 92-94 sidemarker bulb socket
84934AA050 92-94 sidemarker plastic mounting ear
E3610AS940 hitch-mounted bike rack
SOA447D466 power antenna mast
66130AA050 1.5 din pocket
66128AE000 single din pocket
E1017AA100 metal step plates
93073FE580 STi trunk emblem
57497FE000 STi key
SOA307T320 STi stainless mug
SOA307T310 STi black plastic mug
MSA6P8930 Small envelope
Valve cover gaskets - 13294AA012
Valve cover bolt washers - 13271AA051 (3 per side)
Oil filler tube o-ring - 806923060 (its a 23.7x3.5 o-ring if you're looking for an even cheaper replacement)
USDM BOV/BPV: 14471aa001
JDM Turbo inlet rubber boot: 46023fa000
Clutch pedal spring kit: x3601aa000
Two bushings: 36013ga050
spring: 3603711032
Grille - outer clips: 91017AA010
inner clips: 91059FC090
Spark Plug Stuff:
Platinum plugs don't perform better; they just last longer. The problem is that Platinum is actually not as conductive as copper (around 100,000 mho/cm versus 600,000 for copper), so some of the spark voltage is dropped inside the electrodes.
The big selling point with platinum plugs is that they only need to be changed every 100,000 miles or so. To me that's not so great, because the idea of having to remove a plug from an engine after it's been there for 100,000 miles scares me. You also really should be reading your plugs more often than that just to check up on the state of your engine.
It is true, though, that because the platinum electrode won't wear away as easily, you can make then smaller, exposing more of the spark to the air/fuel mixture. But the V-groove does a pretty good job of exposing the spark with copper.
Another issue some tuners may have with platinum electrodes is that you can't adjust their gap. That means you can't experiment with different gaps with platinum plugs unless you buy lots of different platinum plugs, which is expensive. It's not necessarily the case that the optimal gap with a platinum plug will be the same as the optimal gap with a copper plug.
I don't know as much about iridium plugs, but I think that they're basically a step up from platinum. Iridium is even more sturdy and resistant to wear so they last long and have smaller electrodes. Iridium is actually more conductive than platinum, though still nowhere near copper (around 200,000 mho/cm). I think you can gap Iridium plugs too.
Copper with the V-groove is just a good proven cost-effective design... It's been common experience that platinum doesn't perform as well though it does deliver on longevity. I don't know, but it's possible that iridium would perform better due to the smaller electrode. I'll just stick to my $1.30 coppers though.
OVERVIEW:
GET NGK V-POWERS ONLY. RUN COLDER PLUGS ONLY FOR HIGH-ER BOOST APPLICATIONS!!
Now I'm getting lazy, here's links,
Service Manuals, etc.
http://bbs.legacycentral.org/viewtopic.php?t=14485
http://www.1stsubaruparts.com
http://www.allsubaru.com
LCO Suspension Compendium, only 90-94 stuff, as the 95 rear suspension changed. Good basic starting point for matching stuff up, though.
http://bbs.legacycentral.org/viewtopic.php?t=2153
AWD & 5sp Swap writeup:
http://www.surrealmirage.com/subaru/swap/swap.html
NuwanD's Brake upgrade, including ABS removal, and addition of electronically controlled brake-bias. SCHWING!
http://spda-online.ca/modules/newbb/vie ... 0&forum=10
EJ22 engine calculations:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
Basic Tire Size Calculator:
http://www.miata.net/garage/tirecalc.html
4 wire 02 sensors:
http://bbs.legacycentral.org/viewtopic.php?t=14247
STi Legacy Parts List, BC-BF
http://www.main.experiencetherave.com:8 ... slist.html
Lighting tech article: --A MUST READ!
http://www.danielsternlighting.com/tech/tech.html
Early Legacy Locks: (if yours stick, whatever)
http://www.geocities.com/hobiegary/locks.html
Oh, and in case some of you would like to leave a stain on the driver's seat:
http://www.tcsracing.org/scandinavianflick.htm
These guys are friggin' awesome:
http://rhdjapan.com
Just in case you wanted it, here's the thread all about the de-yellowing..
http://bbs.legacycentral.org/viewtopic.php?t=739
I've found that not nearly so many steps are required. Just get yourself some #0000 Steel Wool and go at it with some kind of cleaner, or even water. Later, move to wax, and keep scrubbing 'til you get the results you want. You'll start to see the difference, and eventually, the lenses will *sparkle* again, and you'll know you're about done. Try using a combination of rounded and straight across strokes. I only spent about 10-20mins per light, and then shot 'em with a good douse of clear-coat, so the yellow won't come back. You'll see fine again...
Timing FAQ:
http://bbs.legacycentral.org/viewtopic.php?t=19896
Engine pull and rebuild tips:
http://bbs.legacycentral.org/viewtopic.php?t=18218
Hesistation Issues:
http://bbs.legacycentral.org/viewtopic.php?t=514
and
http://bbs.legacycentral.org/viewtopic.php?t=583
Engine Code pulling, OBD1; various AT tips, (Phase1 4EATs);
http://www.surrealmirage.com/subaru/subaru.html
