Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: 96 Short Throw shifter
    SLi Resident Baddog's Avatar
    Dec 2009
    Portland, Oregon USA
    935
    9,465
    Points: 9,465, Level: 65
    Level completed: 39%, Points required for next Level: 185
    I was doing a few google searches and I cannot for the life of me find a short throw shifter. I check kartboy and rallysportdirect.com.
    What's the deal? Maybe my keywords are garbage.
    1996 Subaru Legacy L
    Jul 2009
    Everett, Wa
    1,531
    7,580
    Points: 7,580, Level: 58
    Re: 96 Short Throw shifter
    http://www.customcarscentral.com/bnm451 ... egacy.html
    I have this one that I scored off a junkyard car for pretty cheap. No need to spend that kind of money though. Also Kartboy's owner works at All Wheel Engineering, but I didn't see a web site for some reason.
    I'd check with 4Zero1Motorsports aka Reason on the boards. He can usually get upgrade parts for good deals.
    NOOB
    Giggity
    oh boy, thats bad for canada!
    Dec 2009
    935
    9,465
    Ill check with him. Whats the difference that there is such a small aftermarket for the oldwr shifters? Linkage?
    9,857
    Yes, the linkage is different depending on the build date. 96 was the crossover year, from what I gather. Either you have this:
    97+ linkage, compatible with many short shifters
    Or this:
    90-96ish linkage, only aftermarket shifter is the B&M or knockoff
    As you can see, the linkage system is completely reversed from each other.
    Link to said knockoff B&M shifter for older models:
    http://www.ebay.com/itm/Subaru-Impreza- ... 853wt_1159
    Dec 2009
    935
    9,465
    Ahhh yeah the linkage I am getting is from a 95. Anyone had good luck with the knock off?
    t3h ub3r m3mber Garrison's Avatar
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Points: 6,153, Level: 51
    Level completed: 2%, Points required for next Level: 197
    Veteran5000 Experience Points
    My B&M knockoff is working quit well, after 10k miles. Just make sure to wrap the center bearing in electrical tape when you install so that it doesn't rattle.
    Dec 2009
    935
    9,465
    So I don't make another thread. Do the WRX Tranny crossmember bushings work on the Legacy? Looking at kartboys
    Dec 2009
    935
    9,465
    Specifically 95-96 Crossmembers (since for some dumb reason TiC claims 97+ is different)
    9,857
    Quote Originally Posted by Baddog
    They claim lots of stuff like that. I think it's because they don't have people with older cars they can test it on. I've been meaning to email them and tell them to add the cobb & kartboy shifter stay bushings to 95+ Legacy as they're listed only for Impreza & newer Legacys.
    I don't believe there's any difference in crossmembers. I know for sure the transmission mount is exactly the same.
    Dec 2009
    935
    9,465
    Okay for 35 I will take a stab at it and order them.
    I was also going to order the kartboy front and rear shifter bushings.
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Spring for the whole kit, it'll save you money down the road. And +1000 for the shift kit. I have it in mine and absolutely love it now that it's broken it. Prepare for a bit of a pain when you install, but as long as you do it right the first time, you should never need to dive back down in there. There's also the TiC tranny stabilizing kit, which is a nice addition, and you have the option of making your own tranny mount out of window weld. That last suggestion makes an enormous improvement in tranny slop, but it does take a couple of days to cure fully (less if baked, or set out in the hot sun).
    Dec 2009
    935
    9,465
    Which whole kit are you referring too?
    I was thinking
    Front and Rear Shifter Bushings
    Crossmember bushings
    Transmission mount
    Short throw
    Dec 2009
    935
    9,465
    I will talk to Reason. Maybe someone will have better knowledge on the subject.
    Not herp derp herp.
    Dec 2009
    935
    9,465
    So the rear shifter bushings are showing up for 98+.
    I am getting EXTREMELY confused here.
    9,857
    If this is what you're talking about: http://www.rallysportdirect.com/COBB-Tu ... er-Bushing
    It'll work on your car.
    Dec 2009
    935
    9,465
    So does anyone know about the TiC pivot bushings for the 95 Linkage?
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Non-existent. You need to do a little DIY in order to drill out your 1-piece linkage, and buy 2-piece linkage bushings in order to do what you're wanting to do.
    Also, I did a double check for you. The kit I was talking about is called the "holy shift" kit, and it's a bit overkill for you. You'll want circular shifter bushings, back bushing, and linkage bushings. Otherwise, I can't think of anything else. Crossmember bushings are a nice touch, especially the added benefit of only having to drop the transmission once to do all of this.
    EDIT:
    Here's the DIY on RS25.com; the site is currently down for maintenance, but the link is good.
    http://s1003.photobucket.com/albums/af1 ... AG0536.jpg
    Dec 2009
    935
    9,465
    Good thing I won't have to drop the trans. Since it's still out of the car until the swap in 2-3 weeks.
    I got the cobb front and rear stay bushings. Where to get the linkage bushings? I am assuming that is if I did the DIY? On TiC's webiste it shows it for 04+ for linkage bushings.
    I see that it's just as simple as installing a brand new linkage. Which I will do.
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Well, hang on.
    The linkage (04-05+) update is nice, but not necessary. You can modify your old linkage with that link for pennies, compared to $50+ for the updated linkage. The 04+ bushings are what you want, check out Turn In Concepts.
    Dec 2009
    935
    9,465
    From what I saw on that link (when it worked 5 minutes ago) was that he just replaced the shifter linkage with a new one.
    Excuse my stupidity. I do not know much about that area by any means.
    Also if I upgraded my linkage I would not be able to use the short throw I purchased, right?
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Hmm. It isn't coming up for me.
    Regardless; to my memory what he does is to drill out the 1-piece shift linkage, replace it with a bolt and then throw the new bushings into his old linkage. It's difficult to explain without pictures, but if you'll read through it a few times it'll begin to make more sense.
    9,857
    I used this link to rebuild the linkage: http://www.ludicrous-speed.com/wiki/ind ... hifter_Fix
    http://www.mcmaster.com has the bushings and I used the MDS filled Nylon ones as they don't wear out as quickly as the ones this guy used. It definitely shored up the slop. Unfortunately, I haven't been able to put the updated, slop free linkage in my car yet.
    edit:
    here:
    http://www.mcmaster.com/#standard-sleev ... gs/=hmg2yc
    click on plastic flanged sleeve bearings, then hit ctrl+F
    Item # 6294K441
    Dec 2009
    935
    9,465
    To rebuild the linkage it looks like i'd have to buy a tap for it. Not bad. I will see what my discount is on a new linkage.
    I will see if a buddy of mine actually has the tools to do this. And then Garrison you claim the 04 TiC linkage bushings will work? Or are those the pivot bushings?
    So this
    http://turninconcepts.com/product_info. ... ducts_id=2
    Covers all 4 bushings on the linkage?
    Aug 2010
    Asheville, NC
    1,019
    6,153
    51
    Mark from Wisconsin to the rescue.
    Mark has the right link, I edited my post above in order to show such.
    If you read Shane's thread, thaaaat's the one you want to follow.
    To answer your question, I have not done this. I wasted my money and bought a new linkage w/ bushings with it from TiC.
    Dec 2009
    935
    9,465
    TiCs website says the linkage update wont work on setups with an external spring. Who knew.
    I will probably just buy a new linkage from the dealer which hopefully has the bushings on it. Which I am assuming it will. At least the 2 that are not "serviceable" and just be done with it.
    Dec 2009
    935
    9,465
    So... Got an email today from the ebay vendor and they are sold out. Anyone know where else to get one?
    9,857
    I actually didn't use the existing rivet and replaced everything with grade 8 3/8" (2.5" length, IIRC & yes, an SAE size fit better than metric) bolts on both of them. The rotate nicely and fit quite well. Just make sure that more than 50% of the shaft of the bolt is smooth, it varies by where you get them. It was a lot easier without the use of a drill press like "Shane" used.
    FWIW, the 90-96 linkage uses bolts and not rivets.
    Looking at their website, yes, it looks like there isn't any hole for the spring to go into. You don't really need the spring (I'm without one because of a boneheaded shop that installed the linkage upside down).
    Dec 2009
    935
    9,465
    Just bought a new joint. Paid 31 with my discount. Also bought the ralco rz short shifter so we will see
    9,857
    Do you have the matching shaft to work with that linkage?
    Dec 2009
    935
    9,465
    Said 93-95 Impreza/Legacy for the short throw. At least the one I bought did
    Or what? Good thing I am having someone help me with this swap.
