Well i just though since no one really posts in here, id just trow something in :-D
Ok, here we go
1.)remove subaru badge from grill
2.)remove all the factory adhesive from back of badge using a razor blade
3.)get some 100 grit sand paper and start sanding, make sure to get all paint off.
*(make sure not to accidently nick the stars or trim around the outside of the badge.
4.)once you finish sanding all the black/blue paint off, you can paint it what ever color you want. your stars will still show, and it looks alot better than stock.
5.) use some sort of water proof adhesive to hold the badge back in place.
This whole process takes about 20 minutes, but its worth it.
im sure most people already know how to do this, but id just though id share the knowledge
