I keep blowing subs and I don't know why!?!?
So here is the equipment
Rockford Fosgate R750-1D amp, its specs are 750 RMS x 1 at 1 ohm.
My first two subs were both Pioneer TS-W2502D2's. This is a 10" 2 ohm DVC sub rated at 800 RMS. The sub was installed in a sealed box that I made from 5/8 mdf, it was the proper capacity for the sub and was glued and stapled, it had no leaks (well one really small one where the wires ran through). The first sub something happened internally, i'm not sure what but when it blew the cone assembly became very stiff, you could not move it. The second subwoofer I was more careful with but eventually the cone separated from the surround leaving a hole about 1 to 2 inches long.
The third subwoofer (which I just installed 3 days ago) is a Alpine type R SWR-10D2 also a 10" 2 ohm DVC woofer rated at 1000 RMS, same box and on my way home today it stopped working. This time the cone is easly moved, I think the cone may have separated from the voice coil.
A little more info, I leave the gain right in the middle, and out of a possible 35 I never turn my head unit over 25 so i should not have a ton of distortion, I do not notice any and I do not have the equipment to test for distortion. I listing to a lot of dubstep and some hip-hop/rap so my subwoofer gets used a lot but am I wrong in thinking it should be able to last at least 3-4 bass heavy songs in a row? As a matter of fact now that I think about it I pounded on that sub for 30 min stright last night, however the sub blew the first song on my way home from work toningt
So am I just the unluckiest person when it comes to subwoofers or am i missing something? Help me out!
