Results 1 to 30 of 51
Thread: DIY: JDM foglight install
Hybrid View
    Eastern Canada
    1,350
    14,099
    77
    Points: 14,099, Level: 77
    *****WARNING! These are measurements I took and are not completly accurate. These are only to be used as a guide. I am not responsible for anyone mangling their bumper.
    Expect to put a lot of hours into this. I took it slow and I put about 12 hours into finishing everything up.
    If any parts need clarification then please tell me and I will fix it!
    Post 1 - General info
    Post 2 - Removing bumper
    Post 3 - Cutting bumper
    Post 4 - Bracket & bumper beam modification
    Post 5 - Mounting
    Post 6 - Wiring
    Post 7 - Finished product
    Tools
    -needle nose pliers
    -phillips screwdriver
    -10mm socket and wrench
    -flathead screwdriver
    -hacksaw blade
    -file
    -wire cutters and crimpers
    materials
    -JDM foglights
    -16 or less guage wire
    -various wiring connections
    -Approx 1" 5/16" bolts and nuts
    -lock washers
    -masking tape
    -electrical tape
    SLi nOOb AssYriaNrocKer's Avatar
    May 2012
    147
    4,045
    Points: 4,045, Level: 40
    Level completed: 48%, Points required for next Level: 105
    Thread saved for later.
    I have the JDM fogs and brackets as well as the USDM fogs and brackets. Has anyone found a better way of mounting these things? This is a great and informative thread but considering this thread is about 6 or so years old a lot of the pictures are missing. The mounting process seems cumbersome and instructions on the wiring is a bit vague.
    Any helpful tips would be appreciated!
    -RONI-
