Ok so I'm sure some of you have seen my posts on here about turbo-ing my car. My question is should I swap out to ej22t pistons or no and if so what kind of head gaskets should I run (turbo or n/a head gaskets)? It's a phase 1 ej22 block with ej25d dohc heads which I'm told will leave me with an 8.8:1 ratio on stock ej22 n/a pistons. I've been told by some the compression ratio would be way too low with ej22t pistons and others say it's a good idea to run them. If this needs to be moved to a different section, then mods feel free to move it. I do apologize for asking a lot of questions I just want to make sure I do this all correctly the first time.
