Page 11 of 11 FirstFirst ... 91011
Results 301 to 323 of 323
  1. #301
    Jan 2017
    NM/NV
    13
    337
    6
    Points: 337, Level: 6
    Level completed: 74%, Points required for next Level: 13
    3 months registered250 Experience Points
    Quote Originally Posted by hupshall View Post
    I took apart my D type BFM to see about getting the security light to work. Although the circuit actually exists on the circuit board, none of the components are present.
    I populated these components and tested the board:
    The other problem is that the gauge silkscreen doesn't expose the security LED, so I carefully cut out the underlying shape (which was a key)
    I put in translucent red acrylic behind that hole and once installed behind the smoked plastic lens of the BFM, it disappears.
    Here it is all complete
    Seems to work just fine.
    When you populated the board, what resistors, diodes, caps, etc did you use? Soldering in some LEDs is pretty straightforward but I'm not sure what to use to populate the other components which are in the circuit. For example, the Security circuit connects to what's labelled as:
    R409
    D401 (which goes to pin 7 on the 30 pin connector)
    C415 & R410 (which I'd assume sets the time constant for the flashing?)
    the sport shift light bulb socket (easy to source)
    D171
    TR172 (perhaps a A1674?)
    CR512
    R174 (SMD?)
    R175 (SMD?)
    Any idea on these? Can you share where you found a diagram or what you did? It would be very much appreciated. I tried taking apart the USDM cluster I took out of my car and it's a different circuit... I have an Impreza cluster I can rob parts off of but this JDM board is a lot more complex than the USDM boards I've messed with before.
  2. #302
    Northeastern CT
    2,617
    I do have a European market cluster which has the security LED preinstalled, so I will take at look at the components there when I get a chance.
    That said, I know that R174, R175, C512, D171, and TR172 are for the sportshift backlight, not the security light.
  3. #303
    Jan 2017
    NM/NV
    13
    337
    6
    Thanks rkrenicki, much appreciated!
    I was just tracing the lines when I came up with those...I definitely could have traced wrong but I believe that one side of the sport shift light is in line with one of the security light diodes. Please do let me know when you have a chance.
    -Romy
  4. #304
    "FNG" FiveZigen's Avatar
    Nov 2016
    Dubai and Toronto
    43
    465
    9
    Points: 465, Level: 9
    Level completed: 30%, Points required for next Level: 35
    250 Experience Points3 months registered
    Super informative thread! Thanks for all who contributed.
  5. #305
    Aug 2017
    6
    Well, after stumbling across this thread, I bit the bullet and bought myself a 85015AE080 cluster for my 2004 H6 LL Bean wagon. My cluster came with about 6 inches of wire as well as the plugs for the three connection on the cluster side. That said, I have a few questions.
    #1 Do the sockets from Mouser include the necessary male pins and a short bit of lead to solder a small gauge wire to? It is tough to tell from the pics and I'm hoping to build an interface harness, as opposed to re-pinning the wiring in my car.
    #2 Are the halo rings supposed to be a very dim beige/brown color? Even at full brightness, by joining C2 & C3, the halo ring colors look pretty "washed out".
    #3 What a good source for the small gauge wiring used in auto harnesses? This looks to be 20-22 gauge wire based on my wire stripping tool.
    Thanks in advance...
    Justin
  6. #306
    Aug 2017
    6
    Quote Originally Posted by FiveZigen View Post
    I second that. I'm very excited to get my BFM cluster installed.
  7. #307
    Northeastern CT
    2,617
    Quote Originally Posted by jhill1977 View Post
    The male connectors do have the pins in them, but be very careful soldering to them as the plastic has a tendency to melt. I recommend removing the pins, trimming them down, soldering, heat shrinking, and reinserting them. They just pull straight out.
    It looks to me that several of your halo bulbs are burned out. They are quite a bit dimmer than the backlight, but they should be pretty noticeable either way.
    Any electronic store or auto parts store will have it. Otherwise there is always Amazon or even Mouser.com
  8. #308
    Oct 2014
    Redmond, WA
    51
    2,478
    Points: 2,478, Level: 30
    Back to the P0462 Error code on non D type BFM's - Looking at the wiring diagram, it looks like this code gets thrown if the input voltage on the ECU monitoring pin of the fuel gauge circuit drops to 0. Honestly, I'm thinking who the heck cares? I'm going to throw together a simple circuit that just always provides 4v to the ECU monitor pin and see if that stops the code from being thrown. It's always a transient fluctuation in the cluster anyway and why the heck the Subaru decided that having a faulty fuel gauge should throw a check engine light I don't know... I'll report back, the parts are OTW
  9. #309
    Northeastern CT
    2,617
    I believe it to be aging solder joints for the connectors on the cluster. I think that the fuel gauge source pin on the cluster has intermittent connection due to a cold/poor solder joint. But, being that I have not worked on an A-C type cluster in quite some time, that is pure speculation.
  10. #310
    Jan 2017
    NM/NV
    13
    337
    6
    rkrenicki - did you ever get a chance to look at the components on your European market cluster with the Security light?
  11. #311
    Northeastern CT
    2,617
    Ah, I had forgotten about this. I pulled it apart and snapped a photo moments ago.
  12. #312
    Jan 2017
    NM/NV
    13
    337
    6
    I hate to be a pain, but I can't read that SMD capacitor or resistor on that board (C415 and R410). Can you check what they say? At least R410; I'd presume a SMD cap of the same size as the C61-C64 group would work and they don't appear to have values on them. I'm also wondering if there's anything connected to the lower part of that circuit. Specifically in the red circle below:
    Sorry to keep bugging you. I've been trying to buy an Euro cluster off of the UK ebay for a bit now, and the guys parting cars there are super flaky and don't want to send pictures for some reason.
  13. #313
    Northeastern CT
    2,617
    Are you asking these sellers for pictures of the inside of clusters?
    As for the parts, decoupling capacitors rarely are labeled with values, but I would guess something along the lines of 0.1uF at 16v. The circled item is a double via, likely connecting to the ground plane of the board. As for the resistor.. I guess I will have to take the cluster apart again. I will try to get to that sometime during the week.
  14. #314
    Jan 2017
    NM/NV
    13
    337
    6
    I'm simply asking for pictures of the clusters themselves. I just want to confirm it's a black face meter and has no damage.
    Thanks for taking apart your cluster again. My background isn't electrical so this is a learn as you go kind of thing.
  15. #315
    Northeastern CT
    2,617
    Quote Originally Posted by Romy View Post
    The BFM was quite uncommon in Europe. It was only on the Turbo B4 in mainland europe, and on the 2002/2003 Outback H6 in the UK. As such, the non-H6 meter is still in Kilometers, but is "LHD" so the inverter box on the back on the opposite side.
    The UK market 2002/03 Outback H6 meter is the only BFM that has an MPH scale, but is only available as an Automatic and the tachometer is tuned for H6 engines.
  16. #316
    Aug 2017
    6
    I've been searching for a 85015AE110 or 111 BFM cluster for a while now. I like that it reads in MPH and includes the security light. If you ever decide to sell yours, I'd be interested.
  17. #317
    Northeastern CT
    2,617
    I actually do have one available. I currently have three in my possession, and only two cars that can use them. I was going to be listing it for sale at some point, but I havent gotten around to it. I will try to get some pictures later this evening and post it up.
  18. #318
    SLi Lurker Lancaster6's Avatar
    Somewhere
    374
    7,016
    55
    Points: 7,016, Level: 55
    Level completed: 33%, Points required for next Level: 134
    Is there a part number or source for the light bulb sockets that illuminate the halos? I thought I had a light out on my BFM, but to my surprise the entire socket has gone missing. It must have rattled out and disappeared behind the dash, as I haven't found it rolling around on the floor. I haven't found it stuck in some nook and/or cranny either...
    Lowered Lancaster6 Wannabe
    2004 Outback H6
    2012 Fancy Honda
  19. #319
    Northeastern CT
    2,617
    The part number earlier in the thread (which I havent looked through at the moment) is for the bulbs with sockets for the whole cluster.. When I get home, I will find the post and quote it here.
    EDIT: Found it back on page 9.
    I was able to get my hands on an original halo bulb kit. There are 8 bulbs in total. The Subaru part number is 85091AE000.
    6 of the bulbs are the larger 14V3WL made by Toshiba. These have a blue base with a yellow paint mark.
    The other 2 are the smaller Type 80 bulb, also made by Toshiba. These have a black base with a blue paint mark.
    Toshibas part number for the larger bare bulb is A7824. It is a 6.5mm-T2 W2.2x5.2D wedge rated for 214mA @14V, with 15 lumens output and a 5000 hour life. Reference "61 431"
    Toshibas part number for the smaller bare bulb is A7429. It is a 5.0mm-T1.5 W2x4.6D wedge rated for 140mA @14V, with 8 lumens output and a 5000 hour life. Reference "80"
    The type 80 bulb is physically the same as a Type 74, except that its operational life is 5 times longer. (5000hrs vs 1000hrs)
    I am trying to find a US source for these bulbs, and I will update this once I find them.
  20. #320
    Oct 2014
    Redmond, WA
    51
    2,478
    The bulb holders are Toshiba V-2, available on Amazon, ebay, etc.. Just look for a T5 twist lock.
  21. #321
    Aug 2017
    6
    Did you ever get around to documenting the process to wire the BFM into the US dimming circuit on the turn signal stalk ?
  22. #322
    Northeastern CT
    2,617
    I have not.. I did write it up earlier in the thread, but the process of taking pictures requires me to pull stuff apart, and I just have not been motivated to do that as of late.
    Perhaps I will make a drawing instead..
  23. #323
    Oct 2014
    Redmond, WA
    51
    2,478
    If you want to do this, it's probably the easiest thing about putting in the BFM - splice the three wires coming out of the BFM dimmer circuit to the corresponding three wires of the dimmer switch. You have to disconnect the dimmer switch from the regular subaru illumination module so you won't be able to dim any of the other lights anymore.
    Honestly, 5 minutes with the wiring diagrams available on this site will show you want to do.
