This thread contains all Wheels, Tires, & Brakes related DIY and threads of note. Please post here if you have anything to add!
DIY
1 person brake bleeding
https://sl-i.net/FORUM/showthread.php?3252
ABS Light On? How to pull ABS codes
https://sl-i.net/FORUM/showthread.php?7354
Wheels/Tires
Bolt pattern / fitment
https://sl-i.net/FORUM/showthread.php?10124
Fender rolling questions
https://sl-i.net/FORUM/showthread.php?1427
Offset information
https://sl-i.net/FORUM/showthread.php?1367
Widest tires you can run without rubbing?
https://sl-i.net/FORUM/showthread.php?761
Painting Wheels
https://sl-i.net/FORUM/showthread.php?6911
Tire Size (and gearing) Calculators
http://tinyurl.com/5mah8l
http://www.1010tires.com/TireSizeCalcul ... ion=submit
Can I replace just 2 tires instead of all 4?
https://sl-i.net/FORUM/showthread.php?4132
Brakes
Rotors: slotted, cross drilled, and plain...
https://sl-i.net/FORUM/showthread.php?979
Stainless brake line compatability
https://sl-i.net/FORUM/showthread.php?1662
Warped Rotors and other braking system myths
http://www.stoptech.com/tech_info/wp_wa ... disk.shtml
