Results 1 to 3 of 3
Thread: How big of spekers can you jam in the doors of a BD?
    SLi Resident ScaryFatKidGT's Avatar
    Sep 2008
    Minnesota
    902
    9,574
    Points: 9,574, Level: 65
    Level completed: 75%, Points required for next Level: 76
    7"? 8"? What mods need to be done? Can you fit an 8" without cutting a whole in the door panel?
    I'm building an Audiophile system around a Pioneer 80PRS going 3 way active (2 way + sub), but I have so much bass I need something to be able to mesh with the subs when I want to have fun. So I need something that can POUND from like 65-70hz up but also meet with the tweets because I only have the ability to run 3 way I can't afford the 99PRS to go 4 way nor do I want to deal with finding a spot for another set of drivers.
    HARRY
    Ride: 98 legacy GT limited: Snorkusectomy, Group A pitch stop, Group A crank and alternator pulleys, Axxis brake pads, SS lines and Super Blue fluid
    9,869
    Re: How big of spekers can you jam in the doors of a BD?
    I would open up the door panels and measure the diameter of the panel that protrudes and cups the speaker opening.
    Theoretically, you could do anything you wanted (within reason) if you had enough time and resources.
    t3h ub3r m3mber harrymaneuvers's Avatar
    Mar 2009
    HighCal (aka NorCal)
    1,789
    11,027
    Points: 11,027, Level: 69
    Level completed: 45%, Points required for next Level: 223
    The largest you can fit in the opening is a 6.5" speaker without cutting anything. Even then... some speakers require spacers to give you enough room to clear the window when it is rolled down.
    If you dont mind cutting/fabbing... you could put 15" subs in each door probably.
    Harry Maneuvers
    1999 Legacy Sedan 30th Anniversary Edition EJ251/EJ22 High Compression Frankenmotor http://sl-i.net/FORUM/showthread.php?15427
    2004 WRX Wagon widebody swap - The Braggin Wagon http://sl-i.net/FORUM/showthread.php?15237
    2006 Forester XT - Mrs. Fancy http://sl-i.net/FORUM/showthread.php?15753
