Go to home depot or your local hardware store and get Vinyl Base Moulding. It's not the lawn gaurd ones, this is used for bathrooms and such. It's usually cost around $2-3 for a strip. on my BD, i had to used 2 strips since 1 isn't long enough.
These are very flexible and somewhat soft. You can use a couple of bolts, washers, and nuts to hold it together. For me, I've used 2 bolts and screws and bolt it at the end of the lip. I also used alot of Guerilla Tape to secure it also
I'll let the pictures speak for itself. Ghetto? I like it, i sure hope it doesn't fall apart
Im not sure what happen to the images, they all are surpose to the the same size. Damn Photobucket
