Results 1 to 6 of 6
Thread: 3rd Gen Fenders: Outback front fenders on a Legacy DIY.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Points: 18,003, Level: 85
    Discussion Ender
    Swapped front fenders with an outback dude looking to do a JDM RS30 conversion. Why? I have the the front subframe off an 05 STI - 20mm wider track. Even with about 2* of neg camber, I would occasionally get rubbing on my rolled stock fenders, depending on wheel offset and tire width. The outback fenders have about 1/4" more flare to them allowing more clearance; besides wider flares are sexy!
    The outback fenders bolt up to all the factory mounting points. However, the only differance is in the lower area where it meets the sideskirts. I chose NOT to run sideskirts (I never really liked the GT ones, liked the more elegant curve the L/no sideskirt has). So I had to fix the fenders.
    2 areas - the trim and the mounting point for the sideskirt had to be modified:
    The trim can be easily addressed by cutting the lower portion and touching up the paint (there's a bump in the outback fender behind the trim, so eliminating the trim altogether isn't an option).
    Time to fill in the bottom hole/mounting point. First flatten it out with hammer. Sand the area off, front and back.
    Then put some mesh to have the body filler something to grab onto.
    Fill in with body filler, sand it down
    Use spot putty to smooth out and pinholes and contours
    Primer, paint, clear coat it.
    Finished!
    Mounting is the reverse
    You may need to massage the bumper cover sides, but they line up very nicely for the most part.
    Now if you aren't as fortunate as me and not have a donor with the same exact paint code, you'll need to have the entire fender painted to match.
    Before:
    After:
    Other views:
    2005 Outback XT
    GO > Show. Every time.
    2,792
    Re: 3rd Gen Fenders: Outback front fenders on a Legacy DIY.
    Looking good!
    Jan 2007
    brooklyn ny
    1,348
    11,922
    Points: 11,922, Level: 71
    omg that first pic is not of my fender is it? Cause i'd think you trashed it by now.
    Install looks good and clean.
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    nah, still have it...of course I'll trash it now
    2005 Outback XT
    "Proby" teeceRS's Avatar
    Dec 2013
    North Carolina
    222
    1,739
    24
    Points: 1,739, Level: 24
    Level completed: 39%, Points required for next Level: 61
    that's a great job filling in the hole! Couldn't you also just put side skirts over the hole though as well? Too bad we can't delete that trim from the outback lower end.
    Don’t tell me the sky is the limit. If there are footprints on the moon!
    '00 Impreza 2.5RS (Sold)
    Black Sheep | Legacy BH9 with a twist
    Cone Eater
    May 2006
    NYC
    3,592
    18,003
    85
    Discussion Ender
    Wow, I forgot I made this thread. To answer ^^, I'm not sure if the sideskirts will bolt straight on as the Legacy skirts go up and under the plastic trim piece as opposed to the OB trim going down into the same space the sideskirts would. I couldn't test that theory as my "special edition" L didn't come with sideskirts (cuz rally car don't need skirts! :P)
    2005 Outback XT
