Results 1 to 3 of 3
Thread: I want opinions about Soldering tools.
    9,857
    I've been doing a lot of wiring lately and my soldering iron is a POS that takes forever to heat up and it's infuriating to use when it actually is hot.
    My brother in law told me I should use a pen torch (butane) instead of a classic electric iron.
    I'd like to hear some opinions and recommendations about what tools rock (and suck) and what tips work best for what, etc.
    SLi nOOb
    Feb 2014
    145
    3,038
    33
    Points: 3,038, Level: 33
    Level completed: 92%, Points required for next Level: 12
    Re: I want opinions about Soldering tools.
    I have a cheap "station". It's nothing more than a temp regulated pencil. It works loads better than the radio Shack pencils I had been using. In my opinion the tip makes the difference, just like tinning the tip when done. I use a sharp cone for PCM 's, and a wide chisle tip for wire - to - wire joints.
    I also turn the dial to nearly the lowest when prepping the next joint. I Tin the tip with solder if I lay it down for even a moment.
    I love to use Flux paste first to encourage the flow of solder.
    2,836
    Butane irons are a pain to get right. I find they are always too hot and end up melting stuff more than it solders stuff.
    I personally use a Weller WTCPT station at work, and a Weller WESD51 at home. I find that they are both fantastic irons, but I really dig the adjustably of the one at home.
    I have heard lots of good things about the Hakko stations, which are a cheap alternative to Wellers. Both the Hakko 888 and 936 are very highly rated and the 936 can be found for under $80 on ebay. The 888 is the newer digital version of the 936.
