Page 3 of 3 FirstFirst 123
Results 61 to 68 of 68
Thread: Grafton's 07 STi
  1. #61
    SLi Lurker Zangado1's Avatar
    Jun 2012
    K.O.P.,Pennsylvania
    426
    5,869
    Points: 5,869, Level: 49
    Level completed: 60%, Points required for next Level: 81
    Tagger Second ClassVeteranCreated Album pictures5000 Experience Points
    What an awesome journey your post has taken. Love your detailed pictures as well. Without a doubt the best year / color and model STI.
    1995 AWD Legacy L wagon 5MT (DD)
    2005 Subaru Legacy GT Limited 5MT
  2. #62
    SLi Supporter Grafton's Avatar
    Jul 2008
    Fairmont WV
    1,728
    12,386
    72
    Points: 12,386, Level: 72
    Level completed: 84%, Points required for next Level: 64
    ^ Thanks
    I've pulled the CAI off the car and gone back to the short ram, every time it rained it would throw a code for the maf voltage, requiring a ecu reset to clear. It'll go back on in the summer, the 4degree above ambient is too good to miss out on.
    Finally got a wide band so that I can monitor the car better and dial the OTS tune in with the intake:
    I've got the 5V out wired into the analog input from the rear O2 sensor so I can log the wideband without needing a laptop and serial cable hooked up.
    Then the multi disk changer died, and I took it apart to attempt to get the disks out and while it was apart I did a color change on the buttons:
    Finally got a turbo blanket from PTP and got around to installing it:
    This is the craziest thing, I left the garage after installing it and did several pulls and quickly pulled back into the garage and was able to touch the turbo heat shield without burning myself.
    2007 Impreza WRX STi
    2012 Impreza 2.0i Premium CVT
    Sold 1997 Legacy L Sedan, 2.5L 12:1 Compression Hybrid, The 'Lego'
    RIP - 2005 LL Bean Outback, The 'Bean' & 1999 Impreza Outback Sport
  3. #63
    Jul 2008
    Fairmont WV
    1,728
    12,386
    72
    Finally getting close to a Protune, so time to make sure the fuel system can handle it
    ID1000's
    DW300
    Install time
    fuel pump was straight forward, but the supplied wires from DW were a smaller gauge than the stock wires
    Assembled pump assembly
    new vs old injectors:
    using the data from Injector Dynamics until a protune in October, wide band was happy during a pull and looks good in closed loop.
    Moved the AOS to make some more room for a GR intercooler that's waiting to be installed
    GR vs GD intercooler:
    Before AOS move:
    after the IAG rotated turbo / Big intercooler bracket:
    GR intercooler bracket is here:
    I didn't feel like trying to fight with the lower end of the bracket where it would bolt to the TGV's
    GR intercooler installed
    Spliter fitment:
    Going to have to do some work on the spliter to get the most out of the bigger intercooler.
  4. #64
    Jul 2008
    Fairmont WV
    1,728
    12,386
    72
    Friend of mine picked up a NA long block, and gave me a light weight pulley that was on it
    Finally got the inter-cooler stencil,
    prepped the engine bay
    Stencil applied
    Painting, 3 coats of high temp red caliper paint
    End result:
    Going on the rollers at EFI Logics this Saturday!
  5. #65
    Jul 2008
    Fairmont WV
    1,728
    12,386
    72
    The big day finally came, got the car up to EFI Logics for a protune by Calvin Dotson of Dotson Tuning.
    Got the car all strapped down
    baseline pull:
    Results
    Before Protune
    265 WHP & 284 WTRQ with some knock in the high rpms
    After
    275 WHP (+10) & 313 WTRQ (+29)
    Knock free and stable AFR
    I've very happy with the way the car is running, much more stable than the bro-tune I had done to get the car "ok" with all the mods it had done.
  6. #66
    "Proby" Go Mifune's Avatar
    Aug 2014
    Evergreen Colorado
    273
    3,924
    39
    Points: 3,924, Level: 39
    Level completed: 83%, Points required for next Level: 26
    People say that Mustangs read low so you might have even more power. Good work!
    1996 Outback 5 speed
    1997 Legacy L wagon 5 speed Member's Ride I thread
  7. #67
    Administrator Huffer's Avatar
    Eastlake, OH / Wellington, NZ
    13,374
    44,297
    Points: 44,297, Level: 100
    Great thread. Thanks buddy!
  8. #68
    Jul 2008
    Fairmont WV
    1,728
    12,386
    72
    Quote Originally Posted by Go Mifune View Post
    I was happy stock, happier when I went stage 2, but the protune is awesome. I wish I'd have done it sooner
    Quote Originally Posted by Huffer View Post
