- Mounting Dual Din
Mounting Dual Din
I just picked up a pioneer dual din head unit for my 98 GT Sedan. Does anyone know of a company that makes a mount kit for it? If not what is everyone else using to mount their dual dins?
Re: Mounting Dual Din
the metal brackets that hold in the DIN radio and the pocket beneath it can be removed and used on the new head unit, keeping the mounting points all the same.
The only thing you will need is a harness if you don't already have one. I just removed a double din that was dying and I didn't need anything extra to change the stereo to a single din.
I will have to take mine a part. It has a single din aftermarket headunit in it right now.
It should slide right in and mount to the existing plates in the car. Just remove the dash plate by the radio and wire it in.
Don't forget the 5th screw on the passenger side of the stock radio when removing it.
- You may not post replies
- You may not edit your posts
Forum Rules
