Results 1 to 6 of 6
Thread: Mounting Dual Din
    Mar 2014
    914
    16
    Points: 914, Level: 16
    Level completed: 14%, Points required for next Level: 86
    Mounting Dual Din
    I just picked up a pioneer dual din head unit for my 98 GT Sedan. Does anyone know of a company that makes a mount kit for it? If not what is everyone else using to mount their dual dins?
    May 2012
    N.Seattle
    86
    3,981
    Points: 3,981, Level: 40
    Level completed: 16%, Points required for next Level: 169
    Re: Mounting Dual Din
    the metal brackets that hold in the DIN radio and the pocket beneath it can be removed and used on the new head unit, keeping the mounting points all the same.
    "Proby" Yokosilver's Avatar
    Apr 2012
    Great Falls, Montana
    242
    6,495
    52
    Points: 6,495, Level: 52
    Level completed: 73%, Points required for next Level: 55
    The only thing you will need is a harness if you don't already have one. I just removed a double din that was dying and I didn't need anything extra to change the stereo to a single din.
    Mar 2014
    914
    16
    I will have to take mine a part. It has a single din aftermarket headunit in it right now.
    New User TheGreenGTBmachine's Avatar
    Feb 2013
    Calgary Alberta, Canada
    18
    2,104
    27
    Points: 2,104, Level: 27
    Level completed: 70%, Points required for next Level: 46
    It should slide right in and mount to the existing plates in the car. Just remove the dash plate by the radio and wire it in.
    "FNG" N'CTRL's Avatar
    Sep 2013
    44
    2,825
    32
    Points: 2,825, Level: 32
    Level completed: 50%, Points required for next Level: 75
    Don't forget the 5th screw on the passenger side of the stock radio when removing it.
